Review & How-To: Black Label Diamond Paint Coating
![](http://autogeekonline.net/nick/Diamond%20Paint%20Coating/pinnacle-black-label-collection-5.gif)
Yesterday afternoon was arguably one of my greatest days at Autogeek. It wasn't because Max let me take his AMG for a cruise on 95 to make sure the governor was still functioning properly, or because I had a coupon for a free Frosty at Wendy's, it's because Black Label - the latest evolution of Pinnacle - was released. Finally.
Max, the owner of Palm Beach Motoring Group, summed it up best when he said...
Originally Posted by Max
The road to creating Black Label was a long and enduring challenge. My team and I spent a great amount of time analyzing and testing different formulas and seeking out raw ingredients that we had never utilized in the past. Like the carnauba waxes and detail sprays that form the backbone of Pinnacle Natural Brilliance line, cost was not a consideration with Black Label. That eliminated one obstacle. The next – and arguably the most difficult – hurdle to overcome was ease of application. I made it clear to my team that, in order for this new breed of products to bear the Pinnacle name, they had to be the best of the best in each category, both in ease of application and overall performance. The products also had to be extremely concentrated, so only a few drops would be required to clean, coat, or protect any given part of your vehicle.
![](http://autogeekonline.net/nick/Diamond%20Paint%20Coating/pinnacle-black-label-diamond-paint-coating-1.gif)
Black Label Diamond Paint Coating with its nano-glass formula is resistant to alkaline cleaners, degreasers, and harsh detergents. Compared to your clear coat, Diamond Paint Coating is more resistant to scratches and marring. The nano-glass formula forms such a hard shell of protection that virtually nothing can penetrate or stick to it, making your vehicle retain that just-detailed shine for years!
Another advantage to Black Label Diamond Paint Coating is the self-cleaning effect that it provides. The nano-glass formula fills in the microscopic pits, pores, and valleys of your vehicle’s paint, creating a perfectly smooth, flat surface. Dirt and road grime will be removed with virtually no effort, making your vehicle easier to clean and maintain.
CREATING A SMOOTH FOUNDATION WITH A CLAY BAR
![](http://autogeekonline.net/nick/Diamond%20Paint%20Coating/autogeek_2267_61304140.jpg)
Gloss comes from smoothness, so the first step is creating a perfectly smooth foundation that’s free of above surface contaminants.
Above surface contaminants include:
Rail Dust – highly corrosive dust created by rail road wheels grinding against the tracks
Brake Dust – highly corrosive dust generated by every vehicle on the road every time the driver applies the brakes
Industrial Fallout – air-polluting byproduct of industrial plants, often contains metals
Tree sap mist – a light spray of sap that sticks to anything in its path
Tar – road tar from construction is often hot when it hits the vehicle and it contains chemicals that are detrimental to auto paint
Bugs – bug remains contain acidic fluids that eat into auto paint
Paint Overspray – Whether the neighbor next door was painting his go-cart with an aerosol-based spray paint, or if your vehicle has spent any time at a body shop, it more than likely has paint overspray on it.
Removing above-surface contaminants is easy. You’ll want to use a clay bar, like Pinnacle Ultra Poly Clay. Here’s a brief explanation of how a clay bar works: The friction of rubbing the bar across the surface combined with the abrasives in the clay essentially sands off the contaminants. The tackiness of the bar holds these contaminants so they don’t get re-introduced into the finish.
SURFACE CLEANSING POLISH – THE MOST IMPORTANT STEP
![](http://autogeekonline.net/nick/Diamond%20Paint%20Coating/pinnacle-black-label-surface-cleansing-polish-1.gif)
When your vehicle was painted at the factory, great care was taken to prepare the surface to ensure that the delicate paint system would remain intact for the life of the vehicle. The same care needs to be taken when preparing the surface for a Diamond coating.
The most important step in prepping the surface for application of a Diamond coating is to use Black Label Surface Cleansing Polish. If you do not use Surface Cleansing Polish before applying one of the Diamond coatings, the result will be complete failure of the coating.
Black Label Surface Cleansing Polish is a non-abrasive, water-based polish that gently removes embedded dirt and grime, restoring a natural brilliance to your vehicle’s paintwork. Use this thick cream to prep your vehicle’s paint, wheels, and glass for application of a Black Label Diamond coating. Water-based formulation promotes proper bonding thanks to its wax, silicone, and oil free formula; polished surfaces can be coated immediately after application.
Black Label Surface Cleansing Polish is a thick cream that can be applied by hand or machine. For this application, I used a Lake Country EZ-Grip Hydro-Tech TANGERINE Hand Applicator.
COATING APPLICATION
Black Label Diamond Paint Coating couldn't possibly be any easier to apply.
- Ensure surface is cool to the touch and out of direct sunlight
- Working one panel at a time, spray Diamond Paint Coating directly onto paint and evenly distribute using a Lake Country Coating Applicator
- Work the coating into the paint until it disappears
- If high spots occur, lightly buff with a Gold Plush Microfiber Towel
Diamond Paint Coating is hyper-concentrated. A single 4 ounce bottle is enough to coat up to 15 vehicles!
FINISHED RESULTS
Black Label Diamond Paint Coating creates an extremely glassy, reflective finish. This type of finish looks especially good on white and silver colored vehicles. For even more shine, Diamond Paint Coating can be topped with a carnabua paste wax or a synthetic sealant.
MAINTAINING THE FINISH
![](http://autogeekonline.net/nick/Diamond%20Paint%20Coating/pinnacle-black-label-diamond-coating-shampoo-1.gif)
So you've applied a Diamond Paint, Glass, Wheel, or Surface coating to your vehicle - now what? First, you'll want to regularly wash the vehicle using Black Label Diamond Coating Shampoo.
Black Label Diamond Coating Shampoo is a hyper-concentrated, high-foaming shampoo that was designed to restore the impressive water beading and sheeting characteristics exhibited by paint and surface coatings. Crystalline nano-polymers encapsulate dirt and grime to prevent wash-induced scratches and marring. Hyper-concentrated formula only requires one pump per gallon of water.
On Autogeek.net
Pinnacle Black Label Collection
Pinnacle Black Label Diamond Paint Coating
Pinnacle Black Label Surface Cleansing Polish
Pinnacle Black Label Diamond Coating Shampoo
Pinnacle Ultra Poly Clay Special
Lake Country Coating Applicator 2 Pack
Gold Plush Jr. Microfiber Towels 3 Pack
It will provide increased resistance to scratching and marring, but I wouldn't dimiss a clear bra just yet. A physical layer of clear film, like a clear bra, is still going to be your best defense against rock chips.
I'm a professional detailer BTW, I do this stuff for a living.
Brian
www.speedfreakdetailing.com
Paint sealant vs surface coating.
I see there is a Black Label Collection product for both. What's the difference? I see that the surface coating is good for all surfaces, however, if this is the case, why does the paint sealant even exist?
