water stains all over
Old Aug 14, 2011 | 06:07 PM
kboustani's Avatar
kboustani
Angry water stains all over
i have a 1989 964 c4 red.i have done the 3 stage paint detail myself 7 weeks ago.i have clayed,polished,waxed the car.it looked amazing.
it was getting a little dirty this weekend,so i took it to a hand wash place.now my car is coverd in water spots.
the guy at the car wash said he had no idea what hapened but wanted to wax my car,i declined.
even my bezel around my headlights has water spots.
i just polished the roof and rewaxed ,but it looks the same.i use meguiar product.
please help as this is driving me crazy.
Old Aug 15, 2011 | 05:56 AM
TOGWT's Avatar
TOGWT
From: London,UK / Florida US State- Dazed & Confused
Removing Water (Spots) Marks - http://www.autopia.org/forum/guide-d...ml#post1448627
Old Aug 31, 2011 | 10:30 PM
kboustani's Avatar
kboustani
any other advice.
Old Sep 2, 2011 | 11:34 AM
Zurichgnome's Avatar
Zurichgnome
Just curious. Did you use a sealant or wax as a top coat when you did your 3-step. The reason I ask is that I did a 3-step on my wife's navy blue car and used a Carnuba as a top coat and also had spotting problems. It just wasn't robust enough as a top coat. Took the wax off and applied Menzerna Power Lock Polymer Sealant. Problem solved. No more spots. I'm sure there are other sealants that will do the trick. Might be an easy fix.
Old Sep 2, 2011 | 04:21 PM
Range Rover's Avatar
Range Rover
I use a dilution of half water/half vinegar. That has always worked for me in situations of removing hard water spots.
Old Sep 2, 2011 | 04:22 PM
kboustani's Avatar
kboustani
range rover,did you wash the whole car with water and vinegar.
Old Sep 2, 2011 | 04:35 PM
Range Rover
I did not, but with a microfiber, I wiped it on the affected areas. If you can, put the mixture in a spray bottle and use it as you would a spray detailer. If it doesn't work, add more vinegar. I typically use straight vinegar, but some people are afraid that it would harm the paint. I've never had a problem.
Hope that it works for you.
Old Sep 3, 2011 | 03:42 AM
Marine Blue's Avatar
Marine Blue
Straight vinegar won't harm the paint if it's not allowed to sit on the paint very long.
Old Sep 3, 2011 | 11:05 AM
MoeMistry's Avatar
MoeMistry
Premium Sponsor
Try a simple paint cleanser first. Do a test area with paint cleanser or a mild polish. If you just detailed and it has a good wax on it, the spots should come off with little effort. Then wax again.
Old Sep 3, 2011 | 09:41 PM
kboustani's Avatar
kboustani
which paint cleanser do you recomend.
Old Sep 4, 2011 | 01:04 PM
MoeMistry's Avatar
MoeMistry
Premium Sponsor
Try this first by hand:
http://www.glisteningperfectionstore...Cleaner/Detail
Don't forget to use your rennlist promo code when you order
