The sky is falling, the sky is falling. Chicken Little
From: London,UK / Florida US State- Dazed & Confused
Pollen
[: Micro gametophytes (pollen grains]
The yellow fines to coarse powders you see in the air is made up of small sperm cells from blooming plants and are one of the most common allergy triggers. The pollen from trees are the main concern, vehicles get hit with pollen laced trees that include: oak, western red cedar, elm, birch, ash, hickory, polar, sycamore, maple, cypress and walnut (which also leaves an oily residue). Pollen grains of pines, firs, and spruces are winged.
Pollen must be strong to protect the male gametes on their journey. The outer wall of the pollen grain, called the exine, is composed of a very unusual substance called sporopollenin which is very tough.
The inner layer is made of cellulose and is similar in construction to an ordinary plant cell wall; pollen will literally ‘wear’ away wax or polymer sealants. Pollen isn't removed by air friction as you drive because it adheres to a surface with microscopic barbs that can attach to even a very slightly uneven surface, and adheres to a natural wax better than a synthetic polymer
As well as being allergic pollen is also very abrasive (due to its exine or barbs) and slightly acidic dust, especially when mixed with moisture and should therefore be removed from paint surfaces as soon as is practicable.
Heavy Dust
To remove heavy pollen dust (do not use a California Duster as the pollen exine (barbs) will cause surface marring) instead use Optimum (OPT) No Rinse Wash™ & Shine New Formula (ONR) a quick ‘wash’; formulated with surfactants to keep dirt in suspension, avoiding surface contact, it also provides surface lubrication, thereby avoiding surface marring. Alternatively use Optimum Instant Detailer - this formulation penetrates and encapsulates light dust (pollen) dirt, and grime, allowing for their removal without scratching or dulling the surface. As soon as is practical, thoroughly rinse the vehicle with a hose and clean water to ensure all the pollen is removed.
Light Surface Dust
To remove light, dry surface pollen dust or pollen without causing scratches by applying very little surface pressure, dusting with long strokes in one direction only, use a product that contains a surfactant; this will lessen surface scratching as they ‘lift’ dust etc into the media used avoiding surface friction (use a solution of Optimum™ no-rinse (ONR) diluted 1:20 / distilled water in a fine mist spray bottle) or Optimum ™ Instant Detailer. Do not use on a hot paint surface (soon after driving) as this will cause streaking?
Use a long nap micro fibre towel to ensure the dust lifted from the paint surface will remain in the nap and not on the towel surface thereby causing surface marring. Shake the towel occasionally to ensure any particles picked up will drop out rather than come to the surface while you’re using it.
Notes: Dust build-up-with low humidity conditions and friction on the paint surface will cause static electricity (this is exacerbated by the use of polyester (nylon) Micro fibre) resulting in dust attraction to the paint surface.
It important to use this methodology only for the removal of dry surface dust, don’t use if surface has condensation or dew, or if the vehicle has oily road film, road tar, damp pollen or dust, etc in these instances the vehicle surface should be subjected to a conventional or Optimum (OPT) No Rinse Wash™ & Shine New Formula (ONR) car washing process
No wax or polymer sealant can provide a permanent shield against: Micro gametophytes (pollen) an acrylic polymer like Klasse or Jeff Werkstat resist acid attack better than most. Collinite 845 Insulator Wax is probably the most durable Carnauba wax product and / or Finish Kare FK425 Detailing Spray; are very good sacrificial protections, but these may only provide enough of a barrier to enable it to be removed quickly before causing too much damage to the paint film surface
No wax or polymer sealant can provide a permanent shield against: Micro gametophytes (pollen) Collinite 845 Insulator Wax is probably the most durable Carnauba wax product; but this may only provide enough of a barrier to enable it to be removed quickly before causing too much damage to the paint film surface
{Knowledge Management} - Treating experience as a shared asset. If this article was informative and you learned something new, or have any questions feel free to comment. We would love if you shared this article with your friends on Facebook and Twitter or linked to it from your website or blog.
Heavy Dust
Light Surface Dust
Good info, thank you for posting....
Any tricks to removing dust from interiors on convertibles?
For reference I've been using a different technique for exterior dust removal for the past 10 years with very good results.
Heavy Dust: Use compressed air to blow the majority of the dust off the car. Best to do this outside and then bring the car immediately into the garage to finish. After the heavy dust is gone I follow up with a light wipe down with a California Duster to remove any remaining light dust. I then follow up with a quick detailer and plush microfiber wipe down.
Light Dust: Same as above but I skip the compressed air.
Sounds like the method using ONR or a similar product would save time since it reduces a step.
How does the finish look after using ONR? I would be very particular about the finish of the paint and if the shine/depth remains the same as it was after waxing. I know that with the quick detailer spray I'm using now (Meguialrs Ultimate) I am able to maintain the depth and reflection for an entire driving season without rewaxing. (Car driven 200 miles/year on nice days only)
