Brake fluid spillage
If the paint is damaged (burned through) then a respray of the area is the only option. If the damage is surface only you may be able to polish it. Can you post a picture of the damage?
Premium Sponsor
+1...post picture
Specializing in Porsche/Ferrari since 1995
Why choose GP...WATCH OUR DOCUMENTARY
Follow Moe HERE
GP Fastrak - Ceramic/PPF/Tint in one simple bundle - Click Here for more info
Follow Moe HERE
compound first and finish polish , not an easy job , the stain is really stuborn.
here is what i worked on.... the wheel was damage/ruined , the paint got a bad stain.
paint before:
AFTER polish : 98% clean
u need a cutting pad and compound ( meg 105) , but if u are not familiar with polishing paint than let a pro to do it for you.
Location: London,UK / Florida US State- Dazed & Confused
Brake Fluid
Common names-Polyethylene glycol usually a mixture of Ethylene, Diethylene, Polyethylene and Triethylene Glycol and monobutyl ether and cleaning additives; pH 9.5 – 10, this alkaline will degrade paint if allowed to remain on the paint surface for any period of time
Correction- remove as soon as feasible using a chemical paint cleaner and then an abraive polish. If paint surface has become degraded a re-spray will be required
