3M Trizact sanding procedures
You will be able to use the 3" inch easier on most panels of your Porsche, as for whether to utilize a PC/DA polisher or an air sander the PC/DA option is more user friendly and you do not need a air compressor.
The trizact discs also work well with the lower orbit speeds that the PC/DA polisher can work at, where the air sander works better with conventional sanding discs.
The PC/DA option allows more precision in tight areas in my opinion as well.
