Plastic panel cleaning and conditioning
hey guys. OT suggested some of you may have some excellent advice on cleaning plastic interior body panels.
These panels will be removed.
I am considering using warm soap and water drip dry and I am confused on the type of conditioner to apply.
WWYD?
WWYD?
Me personally I would get a good brush and mix some sort of all purpose cleaner like Optimum Power Clean to a low dilution like 5:1 with distilled water (assuming the pieces aren't too dirty). Give it a good rinsing and make sure you dry it well so it doesn't water spot.
Since they are interior pieces, you should go with a plastic/vinyl protectant from Einzsett or maybe 303 Aerospace protectant. It depends on how much gloss you want...do a little research on this forum to find out which product looks the best to you. Hope some others will chime in.
I like Einzsett's product in that it lasts a long time and is not too glossy, but it is a bit too slick/sticky and does attract a bit of dirt.
Premium Sponsor
http://www.glisteningperfectionstore...ttle%2C/Detail
As for conditioning, I like einszett Vinyl Rubber Care or Swissvax Protecton. The einszett does have a real slick feel but is easy to work with. Use either product with one of our GP Applicators, and wipe of with a microfiber towel after 15 minutes to give a satin finish.
http://www.glisteningperfectionstore...Care%2C/Detail
http://www.glisteningperfectionstore...x-vinyl/Detail
Specializing in Porsche/Ferrari since 1995
Why choose GP...WATCH OUR DOCUMENTARY
Follow Moe HERE
GP Fastrak - Ceramic/PPF/Tint in one simple bundle - Click Here for more info
Follow Moe HERE
There are many specific products available for interior cleaning, most work well and will get the job done. I personally like Griots Interior Cleaner
Protectants such as 303 Aerospace, Einzett, Griots Vinyl/Rubber and a few others are excellent. They protect with UV Blockers without adding too much shine.
Location: London,UK / Florida US State- Dazed & Confused
Cleaning Vinyl
Like all detailing task’s the correct preparation before applying the product will ensure that it works correctly, and has both durability and aesthetics. Iz einszett 'Plastik-Reiniger' is an intensive, non-corrosive, non-acidic two-phase deep cleaner for vinyl trim and urethane covered automotive upholstery, that removes grime build-up thoroughly and effortlessly, these chemicals restore your interiors original texture and resiliency; use to clean all coloured and clear water-based acrylic polyurethane covered automotive upholstery; this product is biodegradable, formalin-free and environmentally friendly.
Wash vinyl surfaces with soapy water and rinse with clean water and then thoroughly dry. Then use 1z Plastik Reiniger before the application of a suitable dressing.
Protection - with 1z einszett Vinyl Rubber Care & Potectant "Tiefenpfleger” provides a temperature-resistant seal and a low-shine matte finish Dust-resistant and retards the fading effects of UV rays to keep exterior ‘rubber’ and vinyl looking like new.
Application - Spray onto a clean micro fibre towel, agitate lightly and then wipe dry
Vinyl and hard plastic surfaces- (including the dash) apply any dressings very sparingly as these surfaces don’t allow the dressings to penetrate very well. Apply a suitable matte type dressing (Iz Cockpit Premium) to ensure that there is no reflection on the windshield, thus reducing visibility. Alternate with a UVR protection (303™ Space Protectant or Optimum Protectant Plus) especially to the dash and any other surface that is subjected to sunlight on a regular basis
Virtually all vinyl manufacturers agree that (Dimethal Silicones (DMS) should not be used on vinyl (See £Rubber Dressings” - Solvent -based silicone dressings)
