Did you know using a clay bar on your paint is the same as wet sanding??
Administrator - "Tyson"
Wow, learn something new everyday!!! ![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
http://www.f150online.com/forums/car...echniques.html
http://www.f150online.com/forums/3833461-post4.html
Funny things you find on the interwebs....
Wow thats a new one. There definitely are several types of clay on the market and each has a specific use but to generalize the way he does is crazy. I hope this guy doesn't take up smoking while detailing!
For those considering clay, mothers, griots and other detailing type clays are not the equivalent to wetsanding. They are perfectly safe to use and an excellent way to remove surface contaminants. It is important to follow instructions to prevent introduction of new scratches.
Hacker, how can it be that your post count is over a million? Even in ten years of posting every day, that's still three hundred a day!
I think it's pretty common knowledge that posting more than 10 times a day is the same as wet sanding, so you must have worn through the body panels, by now.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Claying your car is the safest way of removing embedded contaminants from the car's paint finish. Continuing to use a clay ball that has seen the ground a few too many times will do more damage to the paint than help.
Premium Sponsor
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
