Black 996 Turbo back to black
This is the second time I have buffed this black Turbo out. It's been a couple years and unfortunately another detailer got his hands on it since last time. In addition to the normal wash marks it also had some holograms, deeper buffer swirls, RIDS, and some fairly deep straight line towel/wash scratches. In addition it had lost it's black and had more of a gray look to it. Porsche paint is some of the nicest tow work on though so I was excited to bring it back to life! I flew out to California and didn't bring my rotary. So all correction was going to happen with my G110.
After doing some test spots I settled on a 50/50 mix of old M105 and UC for my correction. I Then followed that with M205 and finally two coats of NXT2.0.
Complete process:
Wash with GC soap and sheepskin mitt.
Clay with Meg's blue mild and QD as lube.
M105/UC 50/50 via 8006 pad at speed 5.
M205 via 9007 pad at speed 5.
NXT2.0 via 9006 pad at speed .3
Wipe down of sills with microfiber and QD.
Wheels got cleaned with mothers wheel cleaner and polished/sealed with D151.
This was also the first time that I have been able to get M205 to finish down nicely with the process listed on the bottle. 4 passes at moderate pressure followed by 2 passes with light pressure. Previously I had a more clear finish doing 4-6 passes all with moderate pressure. No idea why it worked on this paint but it did and that made me happy.
In these before pics you can see the lack of clarity in reflections, swirls, holo's, scratches, and a general lack of *black* on this car.....it really had more of a muted gray look to it.
![](http://archive.meguiarsonline.com/forums/photopost/data/500/Before110.jpg)
![](http://archive.meguiarsonline.com/forums/photopost/data/500/Before27.jpg)
![](http://archive.meguiarsonline.com/forums/photopost/data/500/Before34.jpg)
![](http://archive.meguiarsonline.com/forums/photopost/data/500/Before42.jpg)
![](http://archive.meguiarsonline.com/forums/photopost/data/500/Before52.jpg)
![](http://archive.meguiarsonline.com/forums/photopost/data/500/Before62.jpg)
The car was then clayed, dried, and finally taped up to prepare for compounding. It was really humid and old 105 was acting a little fussy on my DA. Ultimate Compound didn't quite have the correction I wanted on a yellow pad. So I tried mixing the two of them 50/50 and that did the trick. Plenty of cut and no issues with M105 sticking.
Here's a shot after that combo and before anything else:
![](http://archive.meguiarsonline.com/forums/photopost/data/500/After105:uc.jpg)
I got a late start that day and by the time I was finished compounding it was around 11PM. So I called it a night.
Complete process:
The next morning I gave the car a wipe down with a damp microfiber and some QD to remove any dust left from M105/UC and then went right to work finish polishing with M205 and a black pad. 4 passes with moderate pressure on the machine followed by 2 with light pressure. The black really started to glow now and the finish was very wet and reflective.
![](http://archive.meguiarsonline.com/forums/photopost/data/500/Afterinside1.jpg)
![](http://archive.meguiarsonline.com/forums/photopost/data/500/Afterinside2.jpg)
Once I was done finish polishing I removed all the tape and took the car outside to wash it again taking care to rinse all the body seems and areas where compounding dust likes to hide.
Finally, I applied two coats of NXT waiting 30 minutes for it to cure and 3 hours between coats. The first coat was machine applied and the second was applied by hand. I have not hand waxed a car in a LONG time and thought it would be fun....and it was!
![](http://archive.meguiarsonline.com/forums/photopost/data/500/NXTdrying.jpg)
The chrome wheels had some light brush scratches and a little bit of a haze. D151 was applied and worked in well to polish out the light scratches and bring the chrome back to a mirror shine.
Here is D151 worked in and drying:
![](http://archive.meguiarsonline.com/forums/photopost/data/500/WheelD151.jpg)
And the finished product:
![](http://archive.meguiarsonline.com/forums/photopost/data/500/Wheelafter.jpg)
