Waffle Weave Chamois & streaks
Does your microfibre waffle weave chamois leave streaks? I switched to these because I thought it would be much faster in water removal than a traditional chamois.
I don't put mine in the drier after cleaning it where it might get something on the fabric.
Any suggestions or alternative chamois ideas appreciated.
Your WW is not a chamois, it is made from Microfiber.
How did you last wash it? My guess is that you either used fabric softner in the wash or dryer and that is causing the streaks.
Washing tips for MF:
Do not wash them with any cotton or other clothes or towels.
Hot water
Liquid detergent w/ no softners.
When the washer is done, I add a few small capfuls of vinegar and do another spin/rinse cycle.
Dry on low heat.
Hot water
Dry on low heat.
Philip Yiu
Detailer's Domain
e-mail: phil@detailersdomain.com
website: www.detailersdomain.com
tel: 201-233-0003
Promo code is rennlist for 10% off anything on the site
Current Sales and Updates
Philip Yiu
Detailer's Domain
tel: 201-233-0003
![](http://i46.photobucket.com/albums/f149/pyiu/work/dd_banner_11-1-1.jpg)
Premium Sponsor
Premium Sponsor
Location: London,UK / Florida US State- Dazed & Confused
Always wash towels as soon as possible after use, the longer they sit the more the contaminants will set do not use bleach (bleach will shorten the life of your micro fibre) Read the label on the detergent bottle and use half of what they recommend and use hot water (120oF) Washing Liquid and Vinegar (50/50) to clean-out the machine drum
Heated water breaks down water-soluble soiling faster as it reduces overall chemical usage because it reduces the surface tension of the fibre and will better dislodge wax and other particles. Heat acts as a catalyst promoting quicker reactions between chemicals and the soil thereby minimizing dwell time.
• If the towel still tends to ‘streak’ boil the towels in a water / distilled white vinegar (1/4-cup) solution for at least 20 minute, this will soften the fibres, and release any wax / polish residue. This will also release any lint, which will actually come to the surface of the water. Pre-soak in a liquid detergent / water and then squeeze out wax/polish with your hands and rinse thoroughly.
• Allow micro fibre towels to boil for twenty (20) minutes (ensure that water does not fully evaporate) you will find that more wax / polish residue comes out even after a towel has been thoroughly washed.
• Empty out the water and then remove the towel, don't do it the other way or you'll re-introduce debris to the towel again.
Micro-Restore is the only detergent formulated for maintaining and restoring micro fibre, it’s a concentrated detergent designed to clean, pamper and extend the life of micro fibre cloths. With all of the polishes, waxes, oils and chemicals that we apply and remove with our micro fibre cloths / towels, regular household detergent doesn’t even come close to cleaning or restoring them.
An extract from one of a series of in-depth detailing articles © TOGWT ™ Ltd Copyright 2002-2008, all rights reserved.
