MB Scratched Headlights
Can one of the Gurus tell me what to use, without power tools, to deal with scratches on my 2002 MB E55? I have tried PlastX with very little results. I have also read that I could use a metal polish on the lenses.
There is so much conflicting info out there that I am not sure what to do.
Hints anyone?
Hints anyone?
I've had good results restoring lenses via wet sanding as well. It can remove the scratches, oxidation and pitting easily and after thoroughly polishing to remove the wet sanding marks, the results are crystal clear. Using a buffer will certainly help remove the wet sanding marks. I'd advise taping off all around the lenses so that you don't accidentally wet sand or buff the surrounding areas.
Good luck Ron.
George
Here is a pic of the products I used:
I had some deep scratches so I had to start off with a wet 400 moving up to 2000, then plastic cleaner, then plastic polish.
The results turned out pretty impressive IMO
Good luck!
Google automotive paint "Orlando, FL" and see what pops up
HTH
Ok. I did it this weekend. I started with 800 then 1200 then 2000. I then followed with 3M plastic cleaner then followed with Meguiars plastic cleaner/polish.
It is a lot better but nowhere near perfect. I did it by hand as I have no PC or rotary tools with pads. Will that make a huge difference?
