New vehicle, Initial Care:
Most people believe that a new car needs little if any care for the first week or so, not true. Most new vehicles leave the factory, they sit in dirt parking lots, they are transported by trains, trucks, or ships, and then they are generally subjected to the removal of transit plastic protection wrap and usually harsh washing conditions once they arrive at the car dealership.
Most vehicles are shipped at some point via rail car which is notorious for getting oxidized contaminants onto the paint surface. Even new cars that have been setting on a car dealerships lot for a few weeks can accumulate surface contamination; don't assume a vehicle that looks good is contamination free Acid rain, road salt; tree sap and airborne contaminants are very detrimental to a vehicles paint film surface. Brake dust or rail dust are very small, almost microscopic particles of steel, iron or their alloys.
These particles carry a negative charge while the vehicles they land on are carrying a positive charge. The vehicle surface becomes a magnet, attracting and bonding the ferrous metal particles to the vehicle surface, once you add water (dew, rain, humidity, etc) any of the microscopic particles of steel, iron that have compromised the paint surface will cause rust contamination
If dealer prep has induced surface scratches / marring- use Zaino Paint Cleaner – http://www.zainostore.com/ to remove and then apply a polymer sealant and / or wax for paint surface protection
1. RapGard (Plastic Transit Film):
Many manufacturers are using this white plastic covering in place of synthetic or wax based shipping coatings. Plastic becomes brittle with age (90 to 180 days) and becomes difficult to remove as it "shreds" while being pulled off, additionally there maybe excess adhesive residue left on the surface.
Spray Valugard’s New Car Prep onto the Rapgard, allow to dwell for three or four minutes. Remove NCP residue with a 100% cotton towel (DFTowel) The Rapguard should now gently peel off, pull away from body at a 45 degree angle using an even pressure, you may find that it shreds. The ideal paint surface temperature for RapGuard removal is between 600F (150C) to 800F (260C) If the surface temperature is below 600F (150C) removal is best done inside. Spray the uncovered paint surface with New Car Prep to remove any adhesive residue htpp://www.autoint.com
Wash vehicle with a car wash concentrate diluted 1 oz. per gallon of water any remove any ‘solid’ adhesive residue with detailers clay. The product they use is either Cosmoline (used by Porsche amongst others) or a blend of paraffin and a synthetic wax, but it’s mainly paraffin that is used to protect new cars during shipment. They are sprayed on most engine and exterior finishes to provide a barrier to the elements. (Zymöl Strik™ Cosmoline Remover and Engine Cleaner) will remove it-
Product specific - Zymol http://fp.zymol.com/strik2.htm) or AutoBody Prep (http://www.autoint.com)
Most important; protect the finish with a polymer sealant and / or a Carnauba wax
(See also new Polymer Sealant, Polymer Sealant or Waxing New Paint)
2. Cleaning Wheel Surface:
Clean, properly conditioned wheels, tyres and fender wells greatly enhance the overall appearance of your vehicle. Today's wheels come in a variety of materials and finishes. Clean one wheel at a time, wash wheels and wheel-wells before the rest of the vehicle to avoid dirt and etc. coming into contact to newly washed surfaces. Apply a polymer to the wheel surfaces (Klasse All-In-One)
3. Cleaning Tyres:
•Rinse thoroughly with a fairly strong stream of clean water to remove any loose road dirt etc., from tyre’s and wheel wells.
•Clean tyres with a rubber cleaner (3M Tire & Wheel Cleaner -39036) or a citrus-based APC (P21S Total Auto Wash)
•Use a water-based polymer tyre dressing (Zaino Z-16 Perfect Tire Gloss™)
•Apply a (UVR) protection to the tyres.
4. Detailers Clay:
•Divide the Detailer's Clay into equal pieces and knead into a ball to ensure pliability
•Take one of the pieces and flatten it out into a circle, approximately enough that it will fit into two or three fingers
•Spray a 2-foot by 2-foot surface with a 5:1 lubricating solution (Distilled water / WooliteTM or Dreft™ ensure that the surface being clayed is always wet
•Glide the Clay across the area in a front to back in a straight-line aquaplaning type motion
•Use long strokes without lifting the clay from the surface
•Use a light to medium even pressure until the surface becomes smooth and silent.
•If the Clay is streaking on the paint, you need more to apply more lubricating solution, it is better to over lubricate the paint film surface than let it dry-out
5. Vinyl and hard plastic surfaces:
•Apply any dressings very sparingly as these surfaces don’t allow the dressings to penetrate very well
•Use a suitable matte type dressing (Iz Cockpit Premium) to ensure that there is no reflection on the windshield, reducing visibility.
•Apply a UVR protection (303 Space Protectant) especially to the dash and any other surface that is subjected to sunlight on a regular basis.
6. Surface Protection:
Regularly applied wax and/or a polymer sealant will both protect the paint surface from surface contamination that collects on a painted finish which includes, Industrial fallout (IFO), Rail Dust, Acid Rain, Hard Water Spots, Tar, Bird Droppings, Waxes/Silicones, Oxidation, Adhesive Residue, Road Grime Rust Stains. I would seriously consider the purchase of a clear automotive protective coating (aka Clear Bra)
Use Optimum Poli-Seal and white lake county (LC) polishing pad, this one-step product is perfect for the neophyte or experienced detailer, it will make a noticeable improvement on even brand new paint as it will deepen the shine and jetting (wet-look gloss) durability approx. 3-4 months, maintain the shine with Optimum Spray Wax- http://superiorcarcare.net/oppo.html
7. Car Cover:
The greatest treats to the preservation of your vehicle are; Airborne Contaminants, Industrial Fallout (this includes Acid Rain) Ultra Violet Radiation (UVR) Oxidation, Bird Excrement and Brake Dust, wind blown debris and pollution. Protect your investment with a car cover, outdoors, car covers offer unequalled protection against ultra-violet radiation (UVR) they are water resistant and provide protection from acid rain, pollution, bird excrement, tree sap and wind blown debris.
