Repairing stone chips on a white 944 turbo
I have a few stone chips, very small, on a white 951 (all in the front).
Since the car is white, the chips show more prominently than other cars (due to brown color)
I have bought touch up paint that comes on a paintbrush to match. What's the proper way to repair these chips? How would I remove the rust...sandpaper is way to big for the size of the chip. How would you apply the paint? (toothpick, etc...)?
Location: London,UK / Florida US State- Dazed & Confused
Paint Scratch / Chip Repair:
Why repair paint chips and scratches; to improve the vehicles appearance, to prepare vehicle for lease return, increase retail value and to protect the vehicle from further (corrosion) damage. Chips and scratches aren't just aesthetically unpleasing, the exposed metal underneath may be prone to rusting or additional chipping. Fixing these spots with touch-up paint is an easy step in protecting your investment-
Methodology
1.Apply isopropyl alcohol (IPA) to a Q-tip and dab on the rock chip or scratch a few times.
2.Take a clean towel and dry the paint chip.
3.With a utility knife cut the paint around the edge of the chip, the edge of the paint chip indentation will be slightly higher than the surrounding area and/or the edge of the chipped area may have separated from the metal surface or there could be some wax/dirt in the area or the paint may have oxidized on the edges (it is not absolutely necessary, but it does improve the results and will avoid leaving a dark outline)
4.Angle your blade toward the centre of the chip and press down gently. Work slowly and carefully, removing a small piece at a time, it’s not necessary to remove a lot of material. Clean the area with isopropyl alcohol (IPA) again and allow it to dry.
5.With painters masking tape cover the area surrounding the rust spot
6.Use Nikkens ™3000 grit finishing paper and a Unigrit Sanding Block to remove any rust
7.Use an AutoSharp paint pen (http://www.autosharppen.com) colour matched to your vehicle. The pen itself is very easy to use. You simply shake it, depress the felt tip a few times to start the paint flow, and then begin to "colour" paint into the damaged areas, much like you would highlight a section of text in a book.
8.Do not to try to fix the chip in one application, apply a small amount of paint and ensure that you cover a small area surrounding the ‘chip’, allow to dry, repeat over a couple of days. Once the painted area is slightly higher than paint surface, allow to dry.
9.Once completely dry, using a Nikkens™ 3000 grit finishing paper and a Unigrit Sanding Block (previously soaked for 4 hours or over night) to ‘feather’ and level touch-up paint with the surrounding paint surface
10.Use Woolite® or a car shampoo on the chip repair for lubrication.
11.Use a very light pressure on the sanding block, lightly wiping the area often to check your progress
12.Next, using a Nikkens™ 3000 grit finishing paper and a Unigrit Sanding Block to reduce the high spot off of the chip repair, using the block in one direction only. Do not use a circular motion (it will produce swirls) or a back and forth motion and ensure the sanding block is always wet
13.Keep the area well lubricated with water and shampoo; otherwise it will dull the paint. Once the surface appears level, use a block to squeegee off the excess water / slush (3M™ Wetordry™ Rubber Squeegee, P/N 05517, 2 ¾-inch x 4 ¼-inch) If the water you are using has a high mineral content, don't let it dry on the car, as it could leave spots which may bleed through the new paint.
14.Dry the surface with a clean towel and inspect with your fingertips.
15.If you can feel a high spot, repeat the sanding process.
16.If done correctly, you will hardly notice the repair.
17.A good car polish (Menzerna Intensive Polish or Menzerna Final Polish II ) will restore the paints lustre
18.Finally apply wax/sealant protection
Short version
Paint chip repair (Sal Zaino’s method):
Quote: Here's a fix for the chips. Take isopropyl alcohol on a q-tip and dab in only in the rock chip or scratch a few times. Take a clean towel and dry the paint chip. Take a match out of a matchbook. Use the opposite end of the head. Dab this in touch-up paint. (Do not thin out touch-up paint) Very carefully dab a very, very minute amount in the chip. Do not get any paint anywhere other then the chip depression. The trick here is not to try to fix the chip in one application. Do this every day until the paint in the chip is even with the rest of the paint surface. If you do this correctly, you will hardly notice that chip repair and the colour will match.”
Knowledge; [ability to correctly diagnosis problems] [utilizing appropriate methods / products to solve them]
Methodology
Short version
dally (09-11-2023)
I think your 951 is a base color only paint...similar to the guards red on my 928.....I've used Langka with great success
https://rennlist.com/forums/showthre...ghlight=langka
