S100 Questions...
Just a few questions...
1) S100 polish says that it should be applied w/ a damp foam applicator. That's what I did. But I hear most people use terry applicators for pre-wax polishes?
2) How long should I wait for the wax to be on the car before buffing off? I know it says right before it dries, but approximately how many sec/min is that in 80* heat?
3) How long do I have to wait between coats of S100?
Thanks. I know I'll have more questions so I'll post them hear if I have anything.
I use a foam pad on my pc to apply s100 gloss enhancing polish. I sppray the pad with a quick detailer before applying the polish. If I am doing it by hand I use a microfiber applicator or microfiber towel also presprayed lightly with a quick detailer. As far as the s100 wax which is great I usuall wax one panel and then the next, then go back and remove the wax from the first, again use a microfiber cloth. I assume you are not waxing in direct sunlight.
