Detailers, do you clean the intercoolers?
Question for seasoned detailers.
It just occurred to me that, while we like to keep our cars nice and shiny (including the front radiators) our intercoolers just end up with whatever flows down the air path (water, grime, soap, sealant and a bunch of other crap).
is there a product that’s both safe and efficient enough to shoot in there to clean everything out of there?
do you remove the rear bumper and a few parts to access the outer cores and clean them?
Former Vendor
with enough $ spend, anything can be cleaned and addressed.
P21s total auto wash would be safe I assume.
Air compressor for any look stuff
I wouldnt use a pressure washer and mess up the fins (collapses them if too much pressure)
Yes radiator cleaning should be part of any long term maintenance/care of a car that you intend to keep for a long time. On the Spyder I tape off the trim with blue painters tape and then use a narrrow vacuum wand to suck out the dirt, debris and leaves. Once it’s all cleaned out I gently with a microfiber. For a deeper clean the front bumper would have to come off.
I haven't done this yet, but a low pressure steam cleaning (hand pump w/low pressure) with a gentle degreaser (ie, Simple Green or similar). Or remove cooler and immerse in gentle degreaser..
