paint repair
paint repair
Hey all.. Im tackling paint repair on my 2008 c4s with factory aero kit. Lots of swirls and scratches, and lots of paint chips. I'm planning on using torq 10fx rotary and chemical guys v32-36 line.
Plan to wash, clay bar, and then work my way down from v36-v32 as needed.
couple questions...
At what step do you use the drcolorchip? before using the cutting compound? after?
I attached a picture of the front lip which is fairly destroyed from years of bottoming out... is it best to replace? any way to grind down and repair?
Is it easy to take off, and does anyone have any instructions how to remove it without breaking the clips?
Also, is there a way to take off the Carrera 4s lettering on the back to detail?
couple questions...
I usually do the Dr Colorchip after wash and clay, then Dr. Colorchip, then Polish.
Getting the emblem off is pretty straightforward with dental floss and 3M adhesive remover
With dr colorchip I would do that after polishing, but just make sure that you dont pull too much of the paint out when you are polishing, especially if you use a microfiber cutting pad. So that is up to you on if you would prefer to do it after and just tape around each chip so you dont swirl up the area when using it.
You could sand down and repaint, or use plasti dip, but I would replace. There are instructions out there.
As mentioned, use dental floss, fishing line or something like that along with a heat gun. When removing it try and pull up on the emblem, more than dig down into the paint.
