Installed a water softener and if you think you can't think again
Finally got my water softener installed and I will never be without one again. Because my water service also handles my sprinklers, I could not easily do ALL the water.
I put one inside servicing only the hot water line before it goes to my tankless water heater. I have a hot spigot coming right off the softener to my garage so I have hot, soft water for my cars and motorcycles as well as the hot lines throughout my home.
In addition to the help detailing cars and bikes, it will extend the life of my other appliances and keep the pipes and faucets clearer, and I use 50% of the soap I used to use.
If you are on septic like I am, you can run potassium instead of salt. I would use potassium anyway. It costs beans to operate.
The best part is not worrying as much about getting my Porsche cabriolet top wet and a reduction of spots. Bought mine at www.discountwatersofteners.com Culligan and others were 2 times the price. Or more.
hopefully you aren't washing your car(s) with a microfiber mitt. You're better off using ONR. Also, you may want to check the water hardness (ppm) of the water that you wash your car(s) with. thats the proof that you are not causing micro scratching of the clearcoat.
What is ONR?
Thanks for the post and link, Upscale. I have thought about one for a long time, and each time it's brought up I go and look again.
As for ONR, OR, I guess we both need to go to acronym school.
TTFN
TTFN
