Dallas Area Tool Request
Does anyone have a spring compress or ball joint separator I can brought for a couple days? I don’t want to buy them for one time use.
Thanks,
Tom
tpuorro@cisco.com
Thanks,
Tom
tpuorro@cisco.com
Tom - I've never bought these tools either... couldn't justify the money, although I do have a large tool collection, just not a ton of specialty tools. Like you, I only need them occasionally, so I usually just borrow them from Autozone. Their tool loaner program is great. Their tools are generally in good condition, and they only require a modest desposit to borrow them.
If you can't find anyone locally to borrow from, give Autozone a try. Wherever you get the spring compressor from though - BE CAREFUL. I've seen those things come apart or slip and just about take a hand off. Always keep BOTH ends of the strut pointed in a safe direction... not toward a sheetrock wall in your garage, not toward your car, and not toward any person :-O.
Good luck!
Matt
Good luck!
Matt
Another note on the spring compressor. When we did my brother's Camaro, we ended up taking the strut assy's down to a local Firestone store. They swapped the springs out for something like $30 each, and it only took about 1/2 hour. Much easier and less stressfull then wrestling with "spring compressors" on your garage floor .
