Cayenne no signal
Hello, I would like to post a message so that I can find the solution to my problem which cannot be found on the French forums. I own a 2003 Cayenne 955 Turbo with a total of 116,000 KM. I first had the problem of steering fault with steering wheel locking automatic transmission locking and impossible to start the vehicle the problem got worse the next day without knowing why with the remote centralization no longer work when I open the driver's door the instrument cluster displays nothing when I put the key in the ignition nothing either.... I specify that the fuel pumps work when the door is opened the lights in the vehicle also I can put the radio on , everything works. the battery under the seat is new the one in the trunk too and that doesn't change anything... the splices under the seat are perfectly copper-plated without oxidation I'm totally lost I only have one key that's it... thank you for kindly m bring a little help.
