V8 Oil Change w/pictures
Old 05-14-2012, 01:14 AM
Mike in CA
Mike in CA's Avatar
Default V8 Oil Change w/pictures
As promised a while back, this is a step by step DIY for changing the oil and filter in the latest Porsche Cayenne V8 (Type 958 Model year 2011- ). Hopefully a few tips plus some pictures will help make this a pretty straightforward experience for you. Some of the info is basic for experienced oil changers, but I've included it in case there are some first timers out there who might want to give this a try. Picture taking aside, my first change with the Cayenne took longer as I was eyeballing and taking note of the location of things, but next time I expect it to take about an hour.
What You Need:
Picture 1 shows the items and tools you'll need:
Oil filter
Oil filter cap ring gasket
Drain plug washer
10 quarts of synthetic oil (more on this later)
36 mm 6 or 12 point socket
10 mm socket
T30 Torx bit or driver
8 mm Hex bit
Minimum 12 quart capacity oil drain pan (not shown)
Container for used oil (not shown)
I purchased the filter and gaskets from Suncoast Porsche as a kit, but they are available through many outlets. I'm not going to recommend a particular synthetic oil or viscosity; there is probably as much diversity of thought on this subject as any on Rennlist. You should read the manual and do a RL search, but suffice to say that Porsche recommends the following viscosities:
SAE 0W-40
SAE 5W-40
SAE 5W-50
I use Mobil 1 0W-40. If you decide to go with a different brand just make sure that it meets the Porsche A40 approval spec; that designation should appear right on the oil's label. Depending on your source, with discounts, expect to pay in the neighborhood of $90-$100 for oil and parts (most of it for oil).
Jacking Up the Car:
If you have a garage lift this is a snap, and you also probably don't need any DIY help from an amateur. If you do jack up the car, make sure that it's properly supported by jack stands and that all proper safety precautions are used. You will be crawling fully under the vehicle so don't skimp on this step. As an alternative to jacking the car, Picture 2 shows what I like to do. I place a 2x4 in front of each wheel and drive up on them. This automatically provides an added 1.5" of clearance and keeps the car level which facilitates draining the oil and checking the oil level when refilling. Since I have Air Suspension I raised the car to the highest setting then used my jack as a fail safe under the center chassis cross member. This provided plenty of clearance for me to work.
Removing the Engine Under Trays:
For this step you'll need the T30 Torx bit or driver. There are 14 Torx screws, 10 for the front tray and 4 for the rear. Picture 3 shows the trays in place, Picture 4 shows them removed, and Picture 5 shows them off the car. Remove the front tray first. Note the two "wings" on the front tray; remove these screws before the others as they are harder to reach and you don't want the tray potentially hanging from them. After the front tray is off you can remove the rear tray. You may be tempted to leave it in place because at this point the drain plug is exposed, but a lot of oil comes out when the plug is removed and the rear tray would certainly capture some of it. Before you remove it, note how the back of the rear tray hooks over a slot in the frame and is "sandwiched" in place between the frame and a removable metal piece held by 2 Torx screws.
Drain the Oil:
Make sure that the engine is warmed up (do this before you jack the car). The oil will flow better and contaminants will be suspended and can be flushed out more easily (Picture 6). Use the 8mm hex bit to remove the drain plug. Your catch container should be of sufficient size to accommodate the oil from the sump with enough extra capacity to avoid sloshing over the top when you move it around. I let the oil drain for about 15 minutes or until the flow is reduced to individual drips. While you're waiting for this you can start the next step.
Exposing the Filter
The filter is located underneath the engine on the passenger side at the front. On my car, there is a hose and a bracket that need to be relocated to get to it. (I say on my car because I have PDCC and it appears the hose is associated with that option. If you don't have it you can skip this step.) Picture 7 shows the location of the 3-10mm bolts that need to be removed (one is just out of the picture to the driver's side). The bolt closest to the filter actually separates the hose from the bracket and allows you to tie off the hose to the rear. The bracket will ultimately remain attached by a single remaining bolt that is secured from above, but it's mounted in rubber and the bracket can easily be swung out of the way. Picture 8 shows the now exposed filter housing.
Removing the Filter:
By now the sump has probably drained sufficiently so you can button it up with a new washer on the drain plug. Recommended torque is 50nm or 37ftlbs. Sump and plug are both aluminum: DON'T OVERTIGHTEN. Move your drain pan under the filter housing. The filter cap (and filter) are the exact same ones used on the 997.2 Carrera. A 36mm 6 or 12 point socket is required to remove it. FWIW, this is a change from the earlier V8 which required a 76mm 14 sided cap wrench. Remove the cap (Picture 9), allow the oil to drain and remove the filter element (Picture 10). Picture 11 shows how to remove the old filter ring gasket from the cap. Note the groove in the cap where the ring gasket resides. Wipe down the filter cap, lightly oil the new gasket with fresh oil, and slip it over the cap into place.
Reinstall the filter:
The filter fits snugly over a collar inside the housing (it doesn't matter which end of the filter goes in first), and also a collar inside the cap. As with my Carrera, I like to seat the filter over the collar in the housing first (Picture 12), then center and screw down the cap, but you can fit it in the cap first if you choose. I'm more confident of proper alignment when I do it the first way. Tighten the filter cap to 25nm or 18ftlbs. The cap is plastic; DON'T OVERTIGHTEN. Reinstall the PDCC bracket and hose into their proper positions if necessary.
Add Oil:
You'll want to do this before reinstalling the engine trays, so you can start the car and check for leaks. The stated capacity of the engine and filter is 9.5 quarts, however it is critical that you don't overfill as damage to the engine or catalytic converters can result. Depending on how long and thoroughly you let the engine drain and whether the car is level, a full 9.5 quarts may not have come out. For that reason, I always fill initially to something less than capacity, but enough so that at worst I will be above the minimum level when I start the car. In this case I added about 8.75 quarts. After starting the car and checking for leaks I brought the engine up to temperature to get a reading on the oil level gauge. It read "Oil Level OK" but it was 1 bar low. Each segment of the gauge is supposedly equal to .26 of a quart, but since the point at which the next bar is illuminated is unknown (to me at least) it's best to proceed slowly. Rechecking after each add, I added a couple of tenths of a quart, then 2 more tenths and the guage was at full (Picture 13). Total oil added was about 9.25 quarts. The thing to remember is, don't just dump in 9.5 quarts; sneak up on it and you won't overfill.
Finishing Up:
Time to reinstall the engine trays in the reverse order you took them off. I didn't torque the screws, I just made sure they were snug without tightening them too much. The clips and screws on engine trays often don't fit well on some cars but these all lined up perfectly. The car comes down off the jack stands or whatever and it's ready to go. BTW, if your "service due" indicator has come on, you will need to have your Porsche dealer reset it. Mine does it as a courtesy.
For me, the savings of a few hundred dollars isn't the biggest attraction of doing this job myself. There's not much shade tree maintenance that can be done on cars any more without specialized equipment or expertise, but an oil change can still be one of them. Spending quality time under the hood may not be everyone's cup of tea, but for some reason, it's especially rewarding when that hood is on a Porsche, and this service on the 958 Cayenne V8 is pretty easy. The money savings is icing on the cake.
Mike in CA is offline
The following 4 users liked this post by Mike in CA:
Adams (01-05-2022), TyreReviews (09-18-2022), UNYboater (05-23-2023), wyowolf (06-08-2022)
Old 05-14-2012, 01:26 AM
ArneeA
ArneeA's Avatar
Wow, they don't want just anyone getting to that filter eh?
ArneeA is offline
Old 05-14-2012, 01:35 AM
deilenberger
deilenberger's Avatar
Received 1,141 Likes on 758 Posts
The 4.8 liter engine only has one oil drain plug? The 4.5L engines have two..
deilenberger is offline
Old 05-14-2012, 02:31 AM
Edward 96 Viper GTS
Edward 96 Viper GTS's Avatar
Is it possible to preoil the filter?
Ed
Edward 96 Viper GTS is offline
Old 05-14-2012, 02:44 AM
Mike in CA
Mike in CA's Avatar
It was a snap to move the hose and bracket, and once they are out of the way the housing was easily accessible. I've seen/done oil changes in cars where it was much more of a PITA. Ever done an oil change on a Porsche 993?
One plug.
Ed
If you mean prefill the housing with oil, no.
Old 05-14-2012, 10:59 AM
Slow Guy
Slow Guy's Avatar
Too bad that oil filter cap (w/ the socket) can't be retrofitted to the older 955's.
Another option to using the jack is to drive the front wheels onto 2x6 board pieces. I have a pair of double-stacked 2x6's (apx. 16" long) that I use for this purpose (and they have many other uses too, handy to have around).
Slow Guy is offline
Old 05-14-2012, 11:26 AM
XR4Tim
XR4Tim's Avatar
The hose and bracket are only on cars with PDCC.
XR4Tim is offline
Old 05-14-2012, 11:28 AM
RESP
RESP's Avatar
Very nice work, great pictures!
Thank you Mike!
RESP is offline
Old 05-14-2012, 12:39 PM
Mike in CA
Mike in CA's Avatar
A variation on the theme that get's a bit more work room, esp. valuable on cars without AS. Thanks for the suggestion, Bill.
The docs that John sent me mentioned PDCC but they also showed the filter cap wrench instead of the socket so I was unsure and didn't want to post incorrect info. Thanks for the confirmation; I will edit the original text.
Thank you Mike!
Thanks and you're welcome!
Old 05-14-2012, 01:00 PM
911SLOW
Admin
911SLOW's Avatar
Mike fantastic work, thanks.
I rechecked the instructions I've sent you and it's only on PDCC equipped cars that you have to loosen and lift the hoses.
Also I have to add that Porsche, insists on manually measuring the oil with the PIWIS tester 2, and no longer by using the instrument cluster.. A guideline they've updated twice already.
Now let me CC this thread to Bob so that he can start a P!G DIY section.
911SLOW is offline
Old 05-14-2012, 01:04 PM
w00tPORSCHE
w00tPORSCHE's Avatar
You are god sent Mike.
w00tPORSCHE is offline
Old 05-14-2012, 01:49 PM
Mike in CA
Mike in CA's Avatar
Thanks John. I've edited to included the PDCC info. The bit about the PWIS still confuses me. I assume the gauge is accurate enough for an owner to determine whether and how much oil to add in regular driving, but it's not accurate enough to tell how much oil to top off after an oil change? Maybe PWIS allows for testing without getting the engine to temp and repeatedly checking the gauge in dash saving shop time. Porsche does work in mysterious ways.......
Old 05-14-2012, 01:58 PM
Slow Guy
Slow Guy's Avatar
Just because I feel like being an *** today you could only manually check it with a dipstick or counting the amount of oil you put back in during the change. Using a PIWIS tester is still doing it electronically. I don't imagine they have a 2nd sensor reserved for the PIWIS tester so they must consider the electronics in the gauge setup to be inaccurate. That's weird.
Slow Guy is offline
Old 05-14-2012, 04:46 PM
XR4Tim
XR4Tim's Avatar
The PIWIS is more accurate than the instrument cluster. It shows the oil level value in millimeters, and there is a chart that shows how many mm is considered "full" depending on what type of oil level sensor, and what software your vehicle is running.
I wouldn't be too worried about reading it with the instrument cluster. At worst it may be ½ quart off. Great write-up!
XR4Tim is offline
Old 05-14-2012, 05:54 PM
Andy E.
The V8 Porschephile
Andy E.'s Avatar
Nice write-up Mike! Are those salt stains on the sub-frame?
Andy E. is offline
Quick Reply: V8 Oil Change w/pictures
