Sponsored By:
Sponsored By:
Water pump replacement
Old Jun 11, 2026 | 08:53 PM
phunter's Avatar
phunter
Default Water pump replacement
I have 2019 Cayenne base that just surpassed 100k miles. I want to do preventive maintenance. Spark plugs transmission service and serpentine belts are on my list . Does anyone believe in water pump and thermostat simply based on mileage? I’m afraid of a coolant leak leading to bad things all of a sudden.
what are the things you all would recommend to keep things going well?
thanks in advance
sincerely
p
hunter
Old Jun 11, 2026 | 08:59 PM
chassis's Avatar
chassis
thanks in advance
sincerely
p
hunter
Preemptive maintenance is a good idea. If you don't know when/if the pump and shutoff valve were replaced, doing it now is a good idea.
Also replace the battery at this age/mileage. Your car originally had a LiFePO4 battery. If it still has a Li battery, a conversion kit to AGM is available that saves cost on the battery.
Old Jun 11, 2026 | 10:45 PM
phunter's Avatar
phunter
Thanks for the reply. Will plan for oem water pump. How hard of a job is this for the base 3 liter? Anyone have an experience to share? I try do things myself but don’t want to get over my head.
Old Jun 12, 2026 | 12:03 AM
chassis's Avatar
chassis
@pbon did the water pump on a 2.9TT. The 3.0T in your car has different induction piping vs the 2.9TT and the consensus is that more induction tubing needs to be removed when replacing the water pump on a 3.0T.
After the induction parts are removed, the water pump, thermostat and shutoff valve are the same betwen the 3.0T and 2.9TT.
Old Jun 12, 2026 | 02:13 AM
pbon's Avatar
pbon
As chassis wrote, I changed the water pump, thermostat and coolant shutoff valve on my 2021 Cayenne S with 2.9L twin turbo in early 2021 at about 43k miles. The valve was leaking so I did the other 2 parts as preventative maintenance since it is a pain to get in there. I would call it an advanced DIY job.
I did not remove the front bumper, AC condenser, radiator and fan. One or 2 people tried the job afterwards on 3.0L single turbo and said they could not do it without pulling the bumper cover.
Since I have not done the job on a 3.0L, I should give them the benefit of the doubt. But if I had a 3.0L, I would try since my guess is that I could do it. I will say that it takes a bit of finesse and removing parts in certain orders almost like building a ship in a bottle. It took me maybe 3 hours to get in there. After that the job was pretty straight forward. Putting everything back together is not as hard as taking it apart the first time since you understand how they fit together.
Maybe pulling the bumper makes the job a lot less complicated and is easier overall. It is not as big a deal as people think on modern cars. I have not done it on my Cayenne but have pulled my M5 bumper cover.
Try to find my thread or posts on the subject as well as those from the two people who did the job on 3.0L and then decide what you want to do.
Old Jun 13, 2026 | 04:50 PM
phunter's Avatar
phunter
Thanks for the reply. I am
intimidated by this service position — remove the front bumper concept. I’ll need to research how hard this is to perform and get back straight and even
