Sponsored By:
Sponsored By:
Can the Turbo GT be aligned at any shop?
Old Mar 26, 2026 | 08:06 PM
James Cole's Avatar
James Cole
Default Can the Turbo GT be aligned at any shop?
Hello guys,
I may need to align my 24 TGT but would prefer to
do my local shop, are there any considerations that only the dealer can Align these? Like RWS or connecting piwis for alignment?
Or can it be done by anybody and just hit the numbers ?
Anyone happen to have alignment specs?
Thanks!
JC
Old Mar 26, 2026 | 08:36 PM
retom's Avatar
retom
It's best to have it done at a Porsche dealership. Your new car is under warranty, so there's no point in risking an independent garage doing it wrong.
The Cayenne TGT is a high-performance car packed with electronics, and incorrect alignment can affect the operation of some systems, not to mention the car's handling.
Besides, independent garages may not have the full specifications for this model.
Old Mar 26, 2026 | 09:39 PM
aklim69's Avatar
aklim69
Exactly. And should your independent do it and there is a problem, your fault, Porsche's fault, your independent's fault, nobody's fault, guess who could be on the hook for anything that could be turbo related? Ask me how I know this.
Old Mar 26, 2026 | 11:50 PM
James Cole's Avatar
James Cole
lol how?
Old Mar 27, 2026 | 04:32 AM
Felix's Avatar
Felix
Rennlist Lifetime Member
i had an independent shop do the alignment on my 23 TGT and they probably did a better job than a typical Porsche dealer. In my experience most dealers are happy to have all the numbers “green”; a good specialist looks to achieve symmetry where possible.
Old Mar 27, 2026 | 09:47 AM
James Cole's Avatar
James Cole
Thanks… was any computer stuff necessary? Like calibrating zero point steering wheel?
Old Mar 27, 2026 | 09:49 AM
toma nova's Avatar
toma nova
I’d be going to a specialist, someone that does alignments on all types of performance cars. Dealership alignments will be like oil changes - least experienced tech that can get all green as stated above.
But I only use a dealer for warranty work, never for performance or upgrades (luckily only 1 visit to a dealer in 5 years for the free 10k mile service).
For my Base, I use Firestone - cheap and effective (but not a TGT!).
Old Mar 27, 2026 | 09:55 AM
James Cole's Avatar
James Cole
Thanks! Was more concerned if RWS is a problem…
Anyone have the oem alignment specs?
Old Mar 27, 2026 | 09:59 AM
MSCA's Avatar
MSCA
Just go to a shop that uses Hunter Engineering setup for alignment. Ensure the tech is an experienced one. I got mine done at an Indy by the owner himself.
Old Mar 27, 2026 | 10:02 AM
James Cole's Avatar
James Cole
Originally Posted by MSCA
Just go to a shop that uses Hunter Engineering (Hawkeye or Revolution doesnt matter) setup for alignment. Ensure the tech is an experienced one. I got mine done at an Indy by the owner himself.
Thank you… I like to analyze the specs first for maybe a bit if customization… happen to have your alignment printout?
Old Mar 27, 2026 | 10:14 AM
MSCA's Avatar
MSCA
I don’t save the printout but had posted it on some thread. It’s all computerized, they enter your model and the specs automatically pop up. The specs are in a range but a good tech will configure it at the absolute midpoint for a prefect alignment.
Check them out on YouTube.
Old Mar 27, 2026 | 11:20 AM
golftime's Avatar
golftime
This. Based upon my experience, I concur that most dealers are looking for green and that's about it. My Porsche indy is extremely particular regarding the final alignment settings. If you can find a good performance alignment specialist you can almost be assured of a better alignment there.
Old Mar 27, 2026 | 11:55 AM
retom's Avatar
retom
I'm always wary of any interference from independent garages as long as the car is under warranty. If a major warranty repair is necessary, car manufacturers typically verify that all previous repairs and services were performed by authorized by them garages. They're simply looking for an excuse to charge the car owner for the repair costs.
Old Mar 27, 2026 | 12:56 PM
Kendo67's Avatar
Kendo67
Apart from the rear camber and front toe settings there is no further adjustments available on the "normal" Coupe , has the TGT got multi adjustable components ??
If there are only two adjustments available then i am sure any decent alignment centre should be able to deal with it.
K
Old Mar 27, 2026 | 03:20 PM
MSCA's Avatar
MSCA
K
This isn’t accurate for the Cayenne. The Cayenne has full independent suspension front and rear, so you typically have camber, caster, and toe adjustable up front, and camber and toe in the rear — all four corners. This might apply to a different Porsche platform, but worth correcting here since someone might take it at face value before heading to their alignment shop.
