For the last 40 years, I've dumped the remaining wash bucket over the top of a cold engine then rinsed with the hose. No ill effects. If an engine is really dirty, I'll spray some degreaser (I like Zep 505 from HD), let it sit, agitate with a brush, then scrub with a bucket of Dawn wash. Dump the remaining over, etc.
Don't aim the hose at electrical components and use a wide spray pattern for gentle rinsing. Any scrubbing should be by hand, don't use water pressure to clean.
I am just curious how I am supposed to clean all the remnants of salt from around the coil packs where if left sitting they will ultimately find their way into holes.
If there is a lot of dried salt, you could try Salt-Away product. We use it on the boat after being in salt water and it works pretty well removing salt spots.
You can wash the engine bay by following these guidelines:
1/ The engine must be cold.
2/ The water must be applied at very low pressure. Warm water is more efficient (if possible).
3/ Do not use harsh chemicals, as this will damage aluminum components.
4/ Try to avoid electrical and electronic components.
5/ Be very careful with water spraying from the side of passenger compartment. This area contains the most electronics and has soundproofing mats that absorb water.
6/ After washing, remove the air filter housing and thoroughly blow out all corners of the engine with compressed air.
7/ If possible, leave the car with the hood open for a few hours to allow any moisture to evaporate.
Doesnt it help to drive the car after the wash to have the heat of the engine evaporate the water?
No, it's important to thoroughly blow out the water with compressed air also to avoid leaving white water spots. Driving the car immediately after washing is the worst solution because it increases the humidity in the engine compartment (water vapor - sauna effect), which causes moisture to get into all the nooks and crannies, including the electrical contacts.
Its tough to dry this water when its 37F outside and you have to do this
Does an engine compartment get wet when the vehicle is driven in the rain? Of course it does.
The notion that issues are created if the vehicle is driven after the engine is washed is ridiculous.
That's your theory. Mine is different, and I don't think it's rediculous but it's supported by years of experience. When washing an engine, you pour water into areas that don't get wet during operation. This includes the turbocharger, exhaust manifold, alternator, and many other electronic components.
Anyway, wash your engine as you like.
I would just use some salt neutralizer in a pump sprayer and then gently rinse with fresh water in a small pump sprayer (like a garden sprayer). Stay away from the ECU
Here's a pic of my pump sprayer with salt neutralizer off in the corner of the wash bay
Likewise. Many years of experience.
Driving the vehicle after washing the engine is beneficial, not detrimental.
