Sponsored By:
Sponsored By:
Carbon pads?
Old Sep 2, 2025 | 10:47 AM
pbon's Avatar
pbon
You are right. It is just ceramic coating not powder coating. I was not paying close enough attention reading the earlier posts.
Old Sep 2, 2025 | 02:12 PM
patgilm's Avatar
patgilm
Originally Posted by mark8
Is that light related to the coating process? What exactly is it?
It is infrared light for the ceramic coating. The Feynlab ceramic wheel coating needs a decent amount of time to cure and if you drive before it cures the brake dust could get embedded in the coating so they required you to heat it up with infrared light. I had the outside and inner wheels done as well as the brake calipers. Here are the instructions from the website:
Infrared Curing (Required):
Bake each panel with an IR lamp to reach a surface temperature of 60°C (140°F) for 15min at a distance of ~ 30-36″ from the panel.
Old Sep 2, 2025 | 02:13 PM
patgilm's Avatar
patgilm
Oh I missed that they were being powder coated. I thought the photos were from when they were being ceramic coated.
They are not powder coated, I am talking about ceramic coating my wheels. The wheels are a brushed dark black finish, not powder coated.
Old Sep 4, 2025 | 12:22 AM
3Series's Avatar
3Series
Originally Posted by BuggyChief
thanks for weighing in. The two options you shared don't seem to have Ceramic pads for the 2025. Also, I checked Hawk and neither do they....We can't be re inventing the wheel here...Brake Dust is less than desirable...Surely there is a Ceramic pad option....Hopefully others will weigh in....
This is what I use for a GTS.1 brake:
Dynamic Friction 1600-1349-01
Dynamic Friction 1551-1655-01
Initial bite is less than OEM. You'll get used to it in a day and won't notice it anymore.
Old Sep 7, 2025 | 09:00 AM
BuggyChief's Avatar
BuggyChief
Thanks for sharing. So that is the first Ceramic Pads that I have found. So you have used these? how is the performance? How is the brake dust? I may have to try these. Thanks for weighing in!!!!
Old Sep 7, 2025 | 06:15 PM
BuggyChief's Avatar
BuggyChief
Here is a good link...wonder if anyone has experience with any of these options?
https://www.carid.com/2025-porsche-c...e%5D%5B%5D=GTS
Old Sep 8, 2025 | 09:29 AM
denaliman's Avatar
denaliman
I would not trust Carid. Many of these listed do not show up if you search on the individual manufacturer's sites. If you can confirm the the FMSI pad shape/spec for the 2025 GTS then you could compare.
Old Sep 14, 2025 | 09:42 AM
rhay's Avatar
rhay
look for my post. i changed over to carbon pads and MASSIVE MASSIVE difference. it took me ages to find it.. but i found it.. works really well and a hell lot less brake dust!!! brake bite and feel just the same
works great
I got them from HawkPads Direct --> https://www.hawkpadsdirect.com/colle...m-front-rotors
front and rear ceramic brake pads.
Old Sep 14, 2025 | 10:31 AM
patgilm's Avatar
patgilm
works great
It looks like they only make them up to the 2020MY. I wonder if anyone makes them for a 2025MY.
Old Sep 14, 2025 | 11:11 AM
mark8's Avatar
mark8
My guess is that they haven't changed and they just haven't updated their site yet. Not a lot of volume for brake pads for brand new cars. But this would of course need to be confirmed. Can you see the part number on your pads? I am interested as well. 2025 Turbo eHybrid here... Which I'm guessing has the same brakes as its non-hybrid siblings? I just gave the car its first bath yesterday (only had it 2 weeks) and man, that was a lot of brake dust...
Side note... I have used Hawk HPS several times on past cars and liked them a lot. They did squeal quite ferociously on one vehicle. Make of that what you will. I'm not sure if they would these days or not.
Old Sep 14, 2025 | 04:01 PM
MSCA's Avatar
MSCA
works great
looks like they make pads until MY 2022 only…nothing past that.
Old Sep 15, 2025 | 04:38 PM
3Series's Avatar
3Series
Yes, I use them all the time. I have a Turbo and got rid of the PSCB. They don't bite has hard as PSCB, but they seem to work fine for 99% of the driving in my Cayenne.
I also have gunmetal dark wheels so I don't notice the brake dust as much but seems reasonable.
They should work on a 2025 GTS. See if you can compare the part number or get the Brembo part number off of the actual caliper.
I did a lot of research on this and the calipers don't change often and the same ones are used on different models even if the Rotor diameter changes.
For example, the 958 Turbo uses the same calipers as 9Y0 GTS and the GTS Calipers are the same as the S in the .1 version. If the last couple of alpha numeric match across parts, its the same, the first number designate a generation and color code for the caliper.
Old Sep 15, 2025 | 04:47 PM
3Series's Avatar
3Series
Post up pics of your caliper. Better is to snap a pic of the Brembo number imprinted on it.
I believe all the 9Y0 Cayenne share the same 6-piston Brembo front caliper. The base had a 4 piston early in the generation but has changed to 6 piston.
I also think the rears haven't changed. *This excludes PSCB and PCCB. Panamera also uses similar brakes.
2022 GTS Caliper Part number
Front
9Y0615123AH - That's a Brembo number. I believe that is the number you want on a Porsche caliper to determine if it's the same across models.
9Y0615124AH
Rear
9Y0615424D
9Y0615423D
Old Sep 16, 2025 | 09:43 AM
BuggyChief's Avatar
BuggyChief
Front
9Y0615124AH
Rear
9Y0615424D
9Y0615423D
All- please keep us posted as I have exhausted research on finding ceramic pads for the 2025 GTS. I even called Carbotech and they are willing to make a set, but need shapes and I believe they said a "MSI" number....not sure if I have that correct, but they said it defines the shape? In any event the brake dust is atrocious on the OEM pads. Hoping to find ceramic pads sooner than later as to avoid having to turn the rotors as well.
Old Sep 16, 2025 | 11:37 AM
denaliman's Avatar
denaliman
it is FMSI- Friction Materials Standards Institute. You'll want to get the FMSI-D number. Should be on the side of the pad itself.
FromAI:
What the FMSI System Does:
  • Standardized Part Numbers:
    FMSI created a unique numbering system to classify and identify different brake pads.
  • Common Language:
    The FMSI number provides a consistent, universal way for the industry to refer to specific brake pad applications.
All I could find was this:
https://sbparts.jp/catalogue/51571861/
