Does anyone know how to obtain more information about the procedure the 2025 e-hybrids follow when raising/lowering the chassis? In particular, I've noticed an icon (side view of car with a triangle either above or below it) that appears (sometimes) when changing driving modes, primarily into or out of offroad. I can't make any sense of it because it would seem that if you change INTO offroad then the chassis should raise, which would be indicated by the triangle above, and when shifting out of offroad the chassis should lower back down (triangle below). But the icon doesn't seem to follow that pattern, when I change from offroad to, say, e-power the icon doesn't change. I also don't know if the car raises or lowers when changing into or out of other modes.
Again, I've scoured the owner's manual and searched the internet, but I can't seem to get hold of this particular information. My guess is that it IS in the owner's manual, I just can't figure out how to search for it.
Do controlled experiments. Current gear, drive mode and vehicle speed affect chassis height.
Select chassis height
Select drive mode (NORMAL, SPORT, etc.)
Select gear, e.g. P, R, N, D or paddle shifted gear while in motion
Select constant vehicle speed
Note or photograph MFD chassis height icon
Post results here
