Sponsored By:
Sponsored By:
Instrument Cluster went completely blank
Old 09-30-2024 | 09:14 PM
Cayenneto911's Avatar
Cayenneto911
Default Instrument Cluster went completely blank
My instrument cluster went completely blank on my 2024 Base Cayenne with 5k miles. Restarted the car four times as a restart usually fixes these gremlins, but it remained off. It was a little unsettling driving as I could not confirm the gear I was in, the directionals, lights, etc. Started the car a few hours later and it worked. Did this ever happen to anybody else? I already have an appointment for other electrical issues but the advisor already warned me that if these issues do not occur while at dealer there is not much they can do. I do hope these issues don’t impact safety systems.
Old 09-30-2024 | 10:07 PM
chassis's Avatar
chassis
Slightly different but similar .1 phenomenon - PCM screen goes black. Eventually it reboots and returns to normal function.
Porsche made many mistakes across multiple systems on 9Y0.
Old 09-30-2024 | 10:15 PM
ThomasWShea's Avatar
ThomasWShea
i wonder w the digital cluster if something would be logged error wise because it is critical for it to work.
you are the first person to post on the cayenne forum w this issue that i can recall.
my 2024 coupe has 10,000 miles, never has the cluster gone dark. only issue i have is the - - - displaying for oil pressure and sometimes voltage as well, but if i simply scroll up on that tube then back down the values populate. it is a data issue not a display issue.
Old 09-30-2024 | 10:29 PM
Ron.s's Avatar
Ron.s
Next time, make a video with your phone showing the blank screen and steps you took. That should get past the need to demonstrate a random issue. Some Dealers use this as an excuse but then not all customer complaints are valid..maybr user error or lack of understanding.
My 2023 GTS had the same blank screen numerous times with the Driver screen. After a while it happened more often with the Center screen locking up blank. I also had individual screen data freeze until cycling the ignition. There was a pending update of the firmware that never happened before buyback occured.
VAG is reportedly transitioning to Android Automotive...tthe Audi Q5, 2025 redesign will change over. I have it in my 2024 GMC truck and like it a lot. The new Macan EV is also going to have the Android Automotive operating system.
MAXFPS (09-30-2024)
Old 09-30-2024 | 11:17 PM
Pilot12's Avatar
Pilot12
My map on my 2024 has gone blank in my cluster a few times. Still shows speed, but map is black with nothing to show. Had this happen twice now.
Old 09-30-2024 | 11:40 PM
MAXFPS's Avatar
MAXFPS
I haven't had this happen on my '24 base Cayenne with 6500 miles, but I did notice something about the brilliantly vivid instrument cluster screen (which I think is OLED): it's hot. Like hold the back of your finger on it while it's been running a while - it's crazy hot. Much hotter than the other screens. I'm wondering, is your instrument screen brightness turned up? I'm wondering if your display might have overheated, and so an immediate rebooting/on/off cycling wouldn't fix that, but leaving it off might let it cool down. Was it a particularly hot day?
As I said I've had no issues with mine, but OLEDs TVs run hot and have heatsinks and venting in them to combat it. These screens are new for '24 Cayennes and '25 911s that are just hitting dealer showrooms, but as I understand it they've been in Taycans for a couple years. You might try searching/posting in the Taycan forums to see if they've had similar issues.
Old 10-01-2024 | 12:52 AM
Cayenneto911
Thank you MAXFPS. I was not particularly hot and the car was parked in a covered parking garage so I do not think it was an overheat issue.
Old 10-07-2024 | 06:06 PM
stampineer's Avatar
stampineer
I have not had this on my 2024 Base. I am at 16600 miles.... I am also almost 2k without issue after the fuel injector replacement/update.
Old 10-07-2024 | 10:39 PM
PorscheACC's Avatar
PorscheACC
My 2019 Cayenne S PCM has similar electronic gremlins.
From time to time it goes black.. No reverse camera views, etc.. My vehicle has around 104,500 miles now..
Sometimes, it turns red, which was more concerning to me..
Eventually booted or fixed itself.. Curiously, dealer was never able to reproduce it or find any error logs of any kind, which is troubling and blow minding for a vehicle that costs $120,000+
Old 10-20-2024 | 05:14 PM
Psinclair's Avatar
Psinclair
Default Same for me
My 2019 9Y0 routinely goes blank and reboots after a few minutes. Not reproducible so no way to show it to the dealer. My only guess is that it is running on windows 95.
Quick Reply: Instrument Cluster went completely blank
