Sponsored By:
Sponsored By:
Driver side Window switch - driver's window button broken
Old 09-27-2024 | 02:36 PM
azra's Avatar
azra
Default Driver side Window switch - driver's window button broken
Hello all,
So while I was at a drive through and as I attempted to open the drivers window, the button suddenly broke out of the switch.
Luckily I can just put it back and will still be able to open/close in certain angles.
I've done a lot of research on this and it appears a common issue on older models.
I bought a fake part of Ali Express, what I'm planning is to exchange the broken part with the new button, so I want to extract it from the new unit and try to retrofit in the OEM switch.
As obviously I wouldn't want the un-original version to be on the car, but it could be a last option.
So my question is how do I remove the entire switch, without removing the door panel? if that is even possible.
I could only find videos for the older generation.
and also if anyone has any tips on how to remove/install the individual buttons, that would be great.
Thanks,
Old 09-29-2024 | 02:05 AM
ThomasWShea's Avatar
ThomasWShea
Originally Posted by azra
Hello all,
Thanks,
that whole panel comes out i believe. the only thing i have to reference is my Q8 service manual which has a lot of similarities.
have u looked to see how porsche sells the part? it would not surprise me if they only sell the whole cluster.
i would not put in a non OE switch. i did that once about 25 years ago w my RX7. ended up with little smokies rising up from the switch on a hot day after my girlfriend lowered her window.
Old 09-29-2024 | 12:00 PM
retom's Avatar
retom
There are many variants of this switch panel so I would buy the original. Yes, you have to buy the whole panel, individual switches do not exist. It should come out upwards after prying. When you buy a new one, you will see how it is attached, which will make it easier to remove.
Old 09-29-2024 | 12:25 PM
chassis's Avatar
chassis
958 not sure how different 9Y0 is. Look for Q8/Q7/Touareg videos.
Old 09-29-2024 | 12:54 PM
retom's Avatar
retom
Seems that there is also a way to replace only broken switch.
Old 09-29-2024 | 02:44 PM
chassis's Avatar
chassis
^^ No way I would cut a switch housing apart to install a non-OEM component.
Old 09-29-2024 | 05:57 PM
fstockcarrera's Avatar
fstockcarrera
Hello all,
Thanks,
Amazon Amazon
Bought and installed this in 5 min. Works perfectly. Youtube for instructions
Rob
Old 09-29-2024 | 07:22 PM
retom's Avatar
retom
Originally Posted by fstockcarrera
​​​​​​https://www.amazon.com/dp/B07WRJJ981...fed_asin_title
Rob
Only this is not for 9Y0 which OP has.
Old 09-30-2024 | 04:51 PM
fstockcarrera
Took me 2 secs to find the part on Amazon. My point is that it is an easy fix.
respectfully Rob
Old 09-30-2024 | 11:15 PM
chassis's Avatar
chassis
Haven't found an armrest-only removal video.
Door trim panel removal seems straightforward. 5 plastic trim pieces to remove, then 5 screws, then pop off the door panel from its pin fasteners.
Old 10-02-2024 | 08:05 PM
retom's Avatar
retom
Such a switch panel replacement should also be possible in the Cayenne because it is the same design.
The following 2 users liked this post by retom:
chassis (10-02-2024), Schnave (10-02-2024)
Old 10-02-2024 | 08:34 PM
chassis's Avatar
chassis
Yep, looks like that is it.
Window switch assembly:
https://www.ebay.com/itm/19597778375...Bk9SR_zMpfnJZA
Quick Reply: Driver side Window switch - driver's window button broken
