'22 Base Engine Stumbles/Hesitates
I haven't tried injector cleaner. If that works, will it work with the first tankful? Or will I need to use it multiple times before I see improvement?
I ran a bottle of dry gas through the system a few months back, thinking there might be excess water in the tank (a problem back in the 80s and 90s) but that didn't work.
Such diagnostics show how the injectors are working, the condition of the turbochargers, CO2, MAP, temperature sensors, etc., etc.
It's a bit like a blood test of a sick patient.
In a nutshell, my '22 base stumbles and hesitates when the engine is cold. This happens whenever the car is first started during summer or winter, and whether the car is in normal or sport mode. After the car's been driven a few miles and the engine has come up to temperature, the hesitations and stumbles cease and the car drives acceptably.
I am aware of member complaints about the base engine's rough idle, and my car is no exception to that problem.
This morning I recorded a short video showing how wonderfully smooth my 2022 3.0 V6 and transmission is after a cold start and as I drive away from my house and out of my neighborhood. It isn't all that far from Lexus LS V8 "smooth" except that I can hear the Cayenne's engine. I couldn't hear the engines in my Lexus LS V8 sedans at all at idle and at similar speeds and had to look at their tachometers to verify that they were running. And my hearing is very good according to a fairly recent test. Here's the video from this morning. You might have to turn up the volume to hear my comments since my FITCAMX dashcam isn't all that sensitive to sound. I max'ed the audio level with Clipchamp but it is still pretty low.
It would seem that those having idling and/or driveability issues with the 3.0 V6 have some sort of mechanical or fuel problem.
It’s like teeth whitening strips, need to use a lot of product to get a result. Run through 6 bottles of injector cleaner and report back. 1 bottle will have no effect.
LSR (09-20-2024)
This is very unlikely to be solved by fuel system cleaner and dumping in 6 cans back to back won't help and isn't recommended by anyone.
The correct answer is noted above...use piwis to review engine parameters when the stumble occurs
Edit: And this thread: https://rennlist.com/forums/panamera...-misfires.html
I recently watched a YouTube video that showed a bizarre number of misfires - so many that it was amazing that the engine ran at all.
I don't remember any threads about injector failures in the two years I've been on this Cayenne forum. One reason I was leery about buying anything Porsche was due to the high number of injector failures a friend's daughter had on her VW SUV. So many that she dumped the vehicle in frustration shortly after the warranty expired.
Great question! In situations like this, I believe in first trying the approach that is least invasive and least expensive as long as it is not likely to make matters worse. Based on what everyone has written, I’m going to try injector cleaner. My gut says it won’t work, but it might and it’s cheap and easy. If that approach fails, it’s off to the dealer I will go. The dealer I’ll take it to is the one who just solved my 6th gear vibration problem by replacing the transmission mount, after 3 other dealers said “normal.” Another advantage in trying injector cleaner first is I’ll be able to tell the tech that I’ve tried that approach and it didn’t work. That may get the tech to take a harder look.
chassis (09-20-2024)
I hope whatever you put in the tank doesn't cause the dealer to say you put in an additive and the manual says not to, and we have no further responsibility. I just don't understand why you are taking the step of putting something in the tank when you don't know if that is the problem? Just go to the dealer first. You paid for a warranty - use it!
https://www.porsche.com/china/en/acc.../fueladditive/
Also, Porsche would love it if every hiccup your car has makes you take it to the dealer. That’s their money-maker, the service and parts dept.
FYI clogged fuel injectors are not a warranty item. Don’t confuse a warranty with service wear and tear.
Everything is fine after your engine has been warmed up. Everything is far from OK when the engine is cold. The same engine in my 2022 runs perfectly when "cold" (75 degrees Fahrenheit) with no hesitations or stumbles at all.
Something is defective that starts working better after the engine is warmed up. The challenge is finding what that something is. If I had to guess, it would be something electrical since metal expands as it warms. My guess is that it is something ignition related such as a coil or even a lose connection.
My suggestion is to have a tech do his diagnosis when the engine is cold even if it means leaving your Cayenne at the dealership the day before the diagnostic activity.
Using the fuel additive you were provided isn't going to hurt anything but it doesn't seem appropriate for this problem. Do you buy fuel from questionable sources? It's pretty unusually to get tainted fuel these days - at least in First World countries.
IMO, the above is the key piece of information.
Something is defective that starts working better after the engine is warmed up. …
