Cayenne 9Y0 Pulling to the right
Thanks but that's not the issue. It's called Road Crown.
Mine will go right even if am on Highway last left lane; common sense will think it will pull left... correct??? it does not, it will go right and even cross all the lanes if no intervention. I truly think it's a suspension components being bent or a bearing.... something so small only a good Tech can identify easily and quickly.
Just as an experiment and curiosity. You can also try it on a large flat area like a parking lot if you can safely reach the appropriate speed.
P.S. A bent suspension would be visible when adjusting the alignment or by unevenly worn tires. A damaged bearing is usually noisy.
Motorways are usually tilted to the right. Also the left lane. Find a section of empty road and drive "against the flow" for a bit.
I have a loaner Macan with 21" and surely does not go right on straight line. So Obviously i am not hallucinating.
sooner or later it well get resolved. Made it my mission 🥸
We keep our fingers crossed for your success! Please keep us in the loop.
Careful, I almost caused an accident going the wrong way.
Also, like the video shows if I drive the exact center of a two-laner (yellow solid road line going thru the center console) it does not pull at all.
*** Latest Update ***
The forman is now suspecting the subframe may have shifted and not aligned properly. They will be adjusting it as best see fits and replacing any other components required.
This is very strange.... the efforts continue....
New Update 9/9/24
Vehicle picked up from Service dept. claimed issue fixed. After test driving it; the issue remains the same (Less aggressive pull).
So no Resolution.
I am at loss and no longer know if i should pursuit this and leave it alone. ;-(
So no Resolution.
It's easy to see if the Porsche vehicle is defective..
Just drive another one.. Mine drives straight like an arrow..
Who knows the hisyory of that CPO vehicle, and wonder if that was the reason it was sold/traded/etc by the dealership..
Why waste time on a defective vehicle that can't be fixed even by the Porsche dealer
You must have lots of time to waste on a problem vehicle that not even Porsche mechanics can fix..
You should be enjoying driving a quality luxury vehicle not trying to fix defective/problematic vehicles..
New Update 9/9/24
So no Resolution.
So no Resolution.
My car has been 5 years old and it's still going straight.
PorscheACC (09-09-2024)
One rear broken rubber component repair forced the dealer to perform a 4-wheel alignment, which made it track tighter than the already great tracking it had..
Rennlist Lifetime Member
did you get any alignment spec sheets? if yes, please post them here.
it’s also critical that a full 4 wheel alignment is done; the rear toe being out will cause the car to pull.
I had to specifically ask for a copy the alignment sheet and a copy of the “real” paperwork, complete with prices charged to the warranty company.
