2024 model air suspension problem?
Hi all,
I just wondering is this normal or I have a leak on my air suspension system, my car only have about 700km on the clock!
I noticing after the car been parked on my drive for few days, the rear suspension seem to going down to loading level. It seem the right side is much lower to the left side, is this normal or I have a leak?
when I start the engine the car will go back to normal height. I don’t have any warning lights.
TIA
Roy
TIA
Roy
Hi all,
TIA
Roy
TIA
Roy
Hi all,
TIA
Roy
TIA
Roy
I had a controller module that needed replacement on my ‘24 CS with air suspension. But I got a chassis error about it. That dealer visit wound up being a two month thing, with the service folks discovering a number of additional issues under the car. It all got sorted out, and Porsche took good care of me after it was resolved.
Take it to the dealer and let them look into it. Hopefully it’ll be something simple like just needing a new controller.
mc.porsche (05-14-2024)
Air suspension can develop slow leaks over time, years typically, and leak in extreme cold. Being new and unlikely extreme cold best to head to the dealer. Detail out the length of time it takes to lose a noticeable amount of air and the weather conditions. These slow leaks can be difficult to diagnose so plan an either leaving at the dealer for a while or return visits. The newer air suspensions are pretty reliable. My 2nd Cayenne with air and no problems to report. Big difference from the allroads I had several years ago with the 1st gen air suspensions.
Car is parked on the drive in sunny Spain. Currently the temperature here is about 10c to 15c at night and 20c to 28c during the day.
when I used to live in the cold and wet of Ireland with the older generation cayenne (958.1 & 958.2), I never had any problem with the air suspension.
I thought maybe it is a new feature for easy access lol.
Thanks for all the replies, I will give the dealer a call and see what they gonna do about it.
Hi all,
TIA
Roy
TIA
Roy
My 96,000 mile 9Y0 Cayenne S air suspension still working correctly, leveled, no air leaks, and working as design.
Received 1,241 Likes
Definitely get it addressed. It should not sag. Also, it tends to get worse over time and more expensive to repair.
I had a major $$$ lesson with 958 (previous gen Cayenne) air suspension. Its one corner was sagging if parked for a few days since I got the truck. I thought it was normal. It started to get worse, but I had no time to deal with it due to move from US to Canada. Eventually, just a few weeks after warranty ran out, I got an error message. Once we started parsing what happened, it went from bad to worse - the slow leak in one strut caused the compressor to work overtime, especially after I moved to a colder climate, and eventually the compressor burned out. But even before that, the part that removed moisture from the pumped air stopped working (likely got saturated because new air was pumped all the time) and there was condensation everywhere in the system. They had to replace a whole bunch of valves, sensors and lines to get it all to work, and they had to replace one other strut because the moisture killed a sensor or a valve that could not be replaced separately. And all this unfolded over several months - at first, they only replaced what obviously did not work, but once they replaced one part, soon something else would go bad. So eventually, they replaced almost everything that was likely to hold moisture or be damaged by it, and that put an end to problems, but at a very high cost (the warranty did not work anymore, but after some point, the dealer started to charge me for work at cost out of goodwill).
Lesson - don't let air suspension issues linger. If I replaced it earlier, it would have been just one strut and would have been covered by warranty.
Schnave (04-15-2024)
I think I have the same suspension issue. You mentioned "discovering a number of additional issues". Would you mind sharing what those were? Would like to get everything checked/addressed at the same time during service.
https://rennlist.com/forums/cayenne-...cayenne-s.html
My car had been in the Porsche garage for more than two weeks now, they have replaced the control module and it is still dropping. They going to replace the air suspension it self next.
Unfortunately I am not as lucky as you guys in the US, they don’t have any Porsche loaner car, so they loaned me an Audi Q3 instead 😡
Hi all,
TIA
Roy
TIA
Roy
