Cayenne Tail Light Replacement - what part?
Hello, have a 2022 Cayenne S platinum with clear LED tail light and has a cracked center tail light. The dealer is going to replace it (they cracked it) but it's a platinum edition and clear, does anyone know what part number? I want to make sure the lettering is satin or whatever and not chrome (seems to be an issue despite the VIN input). Thank you!
rajatparihar (11-30-2023)
Thanks so much. I only see it on eBay and some European sites. I imagine I could get this ordered domestically if needed? I would not have found this part number otherwise so thanks again.
No, knowing what i know about the way they make these kinds of things, it is likely made without that kind of maintenance in mind. the plastic is probably heated and bonded permanently together during the original manufacturing. it is more expensive to make something that snaps or bolts together. plus they want it sealed to minimize risk of moisture build up over time.
