Brake dust
Sonax from Germany is a very good product, it makes short work of brake dust, leaves the wheels looking good, and is not expensive. About a bottle will do my 4 wheels.https://www.amazon.com/Sonax-230200-...AQAvD_BwE&th=1
I always wash the brakes to get rid of dust build up on the pad as much as possible. Hasn’t been a problem but if I am putting the car in the garage after the wash I usually do some back and forth dragging the brakes to dry them out. Prevents the surface rust on the rotors.
I use Gyeon Iron. I spray it on, and let it turn purple, then I use a pressure want (I sometimes use a pressure washer but it's not necessary), and the brake dust is gone. Brake dust is ferrous particles coming off of the pads and rotors. I do run a mitt with soap over the wheels very quickly to get rid of the dirt that is not brake dust. I dry the wheels and do occasionally put spray some Gtechniq C2V3 on a microfiber as I dry them. The surface rust on the rotors disappears within the first few miles driven. Before using the Gyeon irion, I spent more time cleaning the wheels than the rest of the car.
Also, when I replaced my brakes, I put on Z23 Powerstop pads. Regardless of what people say, the stopping power is just as good as OEM, and they emit way less dust.
chassis (11-29-2023)
Yes…cuts down on the dust build up on the pads and rotors. After a 2500 mile trip I had a chirp from the rear brake at low speeds. Washed the calipers well and the chirp was gone. I believe washing the brakes regularly helps reduce issues.
The following 2 users liked this post by rdboxster:
chassis (11-30-2023),
importtuner (11-30-2023)
