AC Blowing cold air in the winter
I having this issue and the dealership said that the temperature sensor is reading well above the actual temperature and so blows cold air in response.
Apparently the fuse that my dashcam wiring is on also deals with this sensor and that if they unplug the dashcam the reading goes back to normal.
Is this directly caused by the dashcam? If it is I am confused as to how.
Where should the dashcam be wired to if not the fuse on the left side of the dashboard?
