Sponsored By:
Sponsored By:
USB outlets - Always on?
Old Oct 24, 2023 | 05:54 PM
CaptBrap's Avatar
CaptBrap
Default USB outlets - Always on?
I'm putting an aftermarket dashcam in my 2020 and when I hooked it up to literally any of the four USB-C outlets they all stay on, even when locked.
Does anyone know if they finally shut off after the engine is powered down for a certain period of time? I will not be locking the car as it's in my garage every night.
Old Oct 24, 2023 | 08:39 PM
YHC's Avatar
YHC
My USB ports are off when engine is off regarfdles of door lock
Old Oct 24, 2023 | 11:48 PM
PorscheACC's Avatar
PorscheACC
My understanding is that in the same way that when you charge your battery through the cabin cigarette lighter or when you install 3rd party electronics, when the vehicle controllers detect an active load, it will not turn off the USB power and your battery will become drained, with the vehicle locked or not..
Whenever I forget my Garmin GPS connected to my USB cigarette lighter more than a day, I will find my battery dead and will need to jump start it..
Old Oct 25, 2023 | 10:27 AM
Silververtu's Avatar
Silververtu
USB is active when the engine is switched off.
Old Oct 25, 2023 | 01:05 PM
lakings90's Avatar
lakings90
6th Gear
I have a dashcam plugged into the passenger foot well outlet. The outlet stays on for 30 mins after you shut the engine off. After 30 mins, it turns off
Old Dec 31, 2023 | 09:58 AM
redb202's Avatar
redb202
4th Gear
I plugged mine in the same outlet under the glove box.
Mine stayed on. I parked my car, locked it, went back after 2 hours to check it, my dashcam was still on.
is there a setting somewhere in the PCM that I have to change? Or is there a fuse that I have to move from 1 slot to another to change the outlets from always on to ignition powered? I've seen that option on other cars.
Old Dec 31, 2023 | 01:36 PM
dasams's Avatar
dasams
My dashcam is powered through the OBD port and is on 24/7. However, my dashcam has a motion detector and it shuts off after a short period of no activity. It does not draw enough to affect the battery.
