Lane Keep Assist
Good morning.
A quick question regarding lane keep assist.
I find this system very useful when driving automatically on the highway, but very unpleasant and dangerous on small country roads.
Can we deactivate this function once and for all or do we have to repeat the operation each time the vehicle restarts.
Of course I would like it to work in autonomous driving with the adaptive cruise control.
Thank you for your advice.
Sincerely
Obe
Sincerely
Obe
LKA in my Cayenne sucked. LKA in my A6 was great. You would think the technology would be the same.
ambitin (09-02-2023)
Good morning.
Sincerely
Obe
Sincerely
Obe
I have trouble with the french translator.
It's not the active guidance with the cruise control that bothers me (green steering wheel light),
it's the one that rings and corrects when the white lines are cut. (LKA)
We can deactivate it in the menus but does it come back by default at each restart?
Good morning.
Sincerely
Obe
Sincerely
Obe
I’ve disabled Active Lane Keep Assist as well. Too many times it has been fooled by multiple white lines where previous roadwork was done and tried to take the car where it doesn’t belong. I have disabled it too. Regular Lane Change Assist is OK.
I agree that Lane Change Assist (blinking LED in side mirrors when someone is next to you) works fine.
Lane Keep Assist seems to be invoked mainly when I fail to signal lane changes which is rare. Thankfully, unlike BMW's, Porsches have standard turn signals. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I've driven thousands of miles using Active Lane Keep since buying the Cayenne last summer. ALK sometimes allows my Cayenne to drift to the right when passing highway exits where there is an interruption in the right side lane light but I just manually steer it when that happens. ALK isn't handsfree steering and one should at least lightly keep their hands on the steering wheel. I do occasionally remove both hands from the steering wheel to stretch, get a drink of water, etc., but I stay poised to intervene. I've noticed that ALK can sometimes function with only a lane line on the left side (or only a centerline on 2-lane roads) as long as there are well defined road edges. While my wife was "screaming" at me last fall, I allowed ALK to steer through a series of very sharp curves on a 2-lane rural road while the Cayenne automatically slowed to compatible speeds. I was amazed it could do that. I was also surprised that ALK could keep the Cayenne centered as we topped and descended steep hills - even when there was a sharp curve just over the hill crest. It's quick to react.
I'm less happy with Lane Change Assist due to the warning lights being on the outboard edges of the exterior mirrors. Some Porsches used to have them in the interiors where I though they were much easier to see. There are threads on rennlist complaining about the LCA warning lights being moved to the exterior mirrors. .
can be turned on and off in the PCM. Just uncheck the function. It should not default back to on. I believe the 2024 model change were the function is controlled from so someone familiar would have to answer.
Good morning
THANKS.
I have not yet received my cayenne which is blocked.
But on my previous car, the function could be deactivated EXCEPT since an update at the beginning of the year which activated it by default and required you to enter the car's settings EACH time you start it.
It was very unpleasant and I would like to be sure that it is not the same in the Cayenne in order to have it deactivated before delivery.
Thank you all
Obe
THANKS.
Thank you all
Obe
Good morning
THANKS.
Thank you all
Obe
THANKS.
Thank you all
Obe
