Hey guys , went away for a few weeks , came back and started the cayenne , got the yellow battery light in the dash . I bought a ctek charger , plugged it in . It started charging , went back to check about 5 minutes later , the charger was hot , and not charging. Looks like it won’t acknowledge the charger hooked up .
question
1) is the ctek charger different from the Porsche one .
2) if I disconnect the battery from the truck will it start charging ,
I have tried the reset on the charger but no luck
Also I have read the thread posted on the forum but it’s a lot of 2 word responses that don’t help the problem .
didn’t know owning a cayenne was like a high maintenance chick , god dam !
Does not answer your ctek charger question, but is likely the issue with the yellow light. Was a no charge fix and the yellow light has been off for 6 months.
question
The only difference I see is that my Porsche charger is 5.0 amps. but that shouldn't matter..
1) is your Cayenne totally dead. That is, nothing comes on when you cycle the key?
2) Do you have rear wheel steering which means you have the li-po battery .....
The yellow battery warning light came on. I already had the software update done over a year ago, which had the warning light go away till now. Car starts fine, is it that only the dealer can clear this warning light, or can a scanner like icarsoft do a reset. I never thought I would have so many issues with a Porsche.
Have you use the Porsche or Ctek battery charger to see if your battery charge is just low and to fully charge it before resetting the error?
I would expect that the error code would be an OBDII error code and could be reset with any decent tool..
Update , called the dealer , tryed to get warranty on the battery under emissions because of the start stop feature , they said no . Found a local guy who reprogrammed the battery , lights gone . Can wait for next week to see what might come up , love these trucks , but damn high fn maintenance
Did he re-registered the battery? did he just cleared the error code? or did he programmed the battery internal codes.?
Somebody on here mentioned that he was able to get it covered under emissions.....I wasn't able to either....
