Sponsored By:
Sponsored By:
How does one check the power steering fluid?
Old Jul 19, 2023 | 11:40 PM
fluellen's Avatar
fluellen
Default How does one check the power steering fluid?
Hi,
As the title says - I cannot figure out how to check the level of the power steering fluid. Is there a dipstick somewhere?
I have a groan/whine from the steering wheel intermittently when turning and want to rule out that it’s just low on fluid. 2019 Cayenne turbo.
Thank you in advance!
Old Jul 19, 2023 | 11:56 PM
chassis's Avatar
chassis
Can't do it. There is none. Electric power steering.
Old Jul 20, 2023 | 01:19 AM
fluellen's Avatar
fluellen
Fascinating, I did not realize that. That explains why I can’t find it… Thanks so much!
Any thoughts on what could cause whining/groaning sound from steering? It’s eerily similar to the experience of a failing power steering pump or low fluid in a hydraulic system.
Old Jul 20, 2023 | 02:30 PM
chassis's Avatar
chassis
Does it make the noise you describe when the vehicle is stopped, and you turn the steering wheel lock-to-lock in the parking lot?
Or only when the vehicle is in motion?
Old Jul 20, 2023 | 08:57 PM
fluellen's Avatar
fluellen
Both when stationary or when driving at slow speeds, but only happens very intermittently.
Old Jul 20, 2023 | 10:33 PM
chassis's Avatar
chassis
What do you think about brakes, axle shaft, water pump or wheel bearing? Wheel bearing can be diagnosed while driving at highway speed and swerving (safely) left and right and listening for changes in the sound.
Axle shaft usually is a clicking or knocking sound and can be turned on and off with steering or with increase/decrease of the accelerator pedal.
Old Jul 21, 2023 | 01:20 AM
fluellen's Avatar
fluellen
Thanks for the suggestions. But the sound seems to come very much from the steering column area. I will have it inspected by the dealer as soon as I can. Will update this thread when I have a diagnosis.
Old Oct 1, 2023 | 01:43 AM
fluellen's Avatar
fluellen
An update of sorts: the dealer thinks this noise is most likely caused by a piece of plastic trim or leather rubbing somewhere along the steering column. They offered to take it apart but cautioned that CPO would not cover the diagnosis nor the repair, unless it turned out to be a mechanical failure, which they doubt it is. I was none too pleased about that and declined. I may investigate further myself, or I may try another dealer. But for now the noise has gotten very infrequent - hasn’t really occurred during regular driving over the past few weeks - perhaps it is temperature dependent.
I will update if I discover anything new.
Thanks!
