Glitchy Sat Nav - Anyone Having These Same Issues?
Over this past week, my 2019 Turbo has begun to randomly reset the map view from my default setting in the first picture (450ft scale, Map facing direction of travel) to a new map view in the second picture (6 mile scale, Map facing North). Each time it glitches to the larger view, I need to hit the re-center button or it will stay in the larger view. It’s starting to do this 2-3 times on my daily 40-minute commute, so much so that this is clearly a problem. Everything else on my PCM works fine, and Ive not seen this problem ever before so I thought I’d ask you guys if you’ve experienced the same issue. My Google searches on “2019 PCM Map Problems” seemed to only address the problems of maps not loading but not the problem that I’m seeing.
Any thoughts on this, or should I get myself booked into the Dealer for some warranty work??
chassis (04-08-2023)
