Transfer case
I am being told by my dealer that the temp sensor some of you have also had changed is not present on all models. I have a base and they say there is not a temp sensor to replace on my base model. Can anyone confirm? Thanks
You could check partslink24 ($12 subscription required for 24 hr access) or I will do it tonight.
9Y0 Cayenne Turbo 40,000 mile service $5000? - Page 3 - Rennlist - Porsche Discussion Forums
The temperature sensor is a valid part for 2019 Cayenne base. PCSS indicates replacement of the temperature sensor is required when changing oil in the "transfer gear" aka transfer case aka multi-plate map-controlled wet clutch device.
VIN (from finder.porsche.com) is listed on the screenshot.
Part number with "A" suffix is listed with validity for the VIN.
From reading posts on this site, 992 also requires this temp sensor to be changed when changing driveline oil.
Has anyone confirmed if the vehicle needs to suspended with wheels moving to fill? That seems odd, most t-cases and diffs are almost always stationary fill. A bit weary of overfilling if you do it while having t case engaged.
chassis (03-15-2024)
Stationary fill.
Crawl under the car and look. No bracket to remove. Rubber vibration damper needs removed. Please read the linked DIY thread in detail.
I stationary filled but only got about .4-.5L in before it started over flowing. Anyone else have similar results? I’m wondering if the very slight angle in my garage prevented me from .6 fill as I probably didn’t get all the fluid out
chassis (04-23-2024)
Possibly. Did you measure the drained fluid volume by comparing how much went back into the bottle for disposal?
When I did this the transfer case took significant additional fluid.
