tiptronic shifting strategy
i don't know exactly where to post this. and i've searched.
i have a 2021 cayenne s coupe w tiptronic. the trannie holds gear when i release the accelerator. so, for example, if i accelrate up to 3rd to 6000rpm and release the gas, it holds 3rd all the way down to zero mph. it won't upshift nor freewheel/declutch.
just fyi, i also own a 2011 cayenne turbo (tiptronic) and it behaves like a normal automatic upshifting or freewheeling when the accelerator is released.
bothered by this, i took it in and service insisted that this was normal. i actually drove a loaner with the qc guy in along for the ride and same thing: it proved that it is indeed 'normal'.
so, what's 'normal' about this? did porsche change it's shifting strategy for tiptronic's somewhere along the way? and if so, why?
thanks for your kind attention
Heegoogoo1 (01-22-2022)
of course in manual mode it behaves correctly
i've never run into this. the porsche guys can't explain it. they simply say 'they all do that'
that's called compresion braking, which of course you use in a manual shift car (or here, in manual mode). in an automatic, releasing the gas releases the gear and in modern transmissions, for fuel economy purposes, it often upshifts.
My Cayenne coupe does the same ,I think since it’s a sports car ,it needs always to be ready for acceleration not like a classic car .
thank you. as i said, the 2nd one i drove did the same. so the question for porsche is, why? and when did this change as my 2011 acts normally and does not hold gear on lift-off throttle.
Heegoogoo1 (01-30-2022)
I remembered your post during today’s drive, so I did a little test. My Cayenne behaved the same as yours. It held 3rd and remained engaged to the engine while coasting to a stop. It shifted to 2nd, then 1st below approximately 5 mph.
I did another run, and while coasting, I applied mild throttle to maintain speed, The transmission shifted into 4th, then 5th as you would expect. Sounds like this is normal for a Cayenne.
I took a drive in my GTS this afternoon in comfort mode. I drove it to around 70 km/h and 5th gear and then took my foot off the gas and let the car slow down. I saw the gear numbers change from 5-4-3-2 as the vehicle slowed down and then to 1 just as it was coming to a stop. The vehicle never downshifted in such a way as to make the downshift noticeable without looking at the gear selector number in the display. I also notice that if I don't come to a complete stop (i.e. a rolling stop at a stop sign), the transmission stays in 2nd and starts off in that gear. I suspect that has something to do with fuel savings and making use of the V8's torque. But I didn't try that when I test drove an S model. When I increase speed, and then stop accreting, the transmissions upshifts to the next gear and then as speed increases it upshifts again until I'm going around 80 km/h at which point it shifts to 8th gear. Hope this helps.
thank you
why is this important? if you're in a passing situation on the roadway, and you nail it and drop down two gears, it will stay in that lower gear indefinitely until you give it gas. it will not upshift. it stays in the lower gear. as though you're in manual mode and holding the lower gear. this isn't right, and i wish porsche or a tech would weigh in on this to explain why this is so and why it has changed. it's objectionable to me
OK, Maybe I'm not understanding what you are saying. I think I asked if you are operating the transmission in manual (by that I mean - shift lever to left and manually selecting, or using the paddles) and I understood you to say no. So for me to get the transmission to get to 5,000 rpm in 2nd, I'd need to press the accelerator at least 1/2 or the car will upshift pretty rapidly. If that is the test you are after I'll give that a try (if I can find some dry pavement around here - mostly slippery surfaces after yesterday's snow).
