Wheel fitment from last gen cayenne on latest gen
Hi All,
A friend is offering me 19” OEM winter set from older cayenne (I think 2016) and I have a 2022 GTS on order. Just wondering if the wheels will fit and if there is anything specific I should check.
Thanks!
Thanks!
It depends on which brakes you ordered. Check out this thread for minimum wheel size and offsets:
https://rennlist.com/forums/cayenne-...-e-hybrid.html
It looks like the offset of all the wheels changed by about -10mm since the previous generation. However, the 19s from any previous generation have outside dimensions smaller than the biggest wheels available on the current gen. They should fit no problem. I wouldn't hit the track in your winters, but that would be a pretty sweet setup IMHO for snow and ice. Also make sure you clear the brakes as mentioned above.
