Tyre pressure?
Tyre pressure?
Hi my car board (the one in the front door says 38psi front and 41 rear wheel ) while the dash pcm says 42 front and 45 rear ? Which one I’ll follow .?
my wheels are irrelli
front
285/40 ZR 21 (109) y xl pzero (No)
Rear
315/35 ZR21 (111) y xl pzero (No)
thanks
front
Rear
thanks
38 front and 41 back is when you have 2+ people plus lugagge. Its a weight mesure.
if that is what u want. Its ok.
and the mesure in the dash can be reset to the value you want. Soo you that screen with the -1 is for
what i had reset your psi stats to.
you should set your 2 front to 38 and 2 back to 41 then reset your mesure in dash. Then your all set
Heegoogoo1 (05-25-2021)
That's the one you need to follow, because it uses those settings for tire pressure warnings.
PorscheACC (05-25-2021)
