Sponsored By:
Sponsored By:
Spacer question
Old Sep 13, 2020 | 03:49 PM
Tiberius's Avatar
Tiberius
8th Gear
Default Spacer question
I've always put spacers on my 911s as I enjoy the aesthetic look of a flush wheel. I have a Cayenne GTS coming (my first SUV) and was curious to know if anyone has installed spacers or if it is possible on a 22 inch wheel. I'm not talking about anything outlandish. Perhaps 15mm or 17mm but I'm not sure.
Any feedback and/or pics would be appreciated.
Old Sep 18, 2020 | 09:41 PM
David Mackintosh's Avatar
David Mackintosh
​​​​Spacers are exactly the same as running a wheel of the same width with less offset. I have no idea if you're likely to get rub, you should run one rear wheel up on a ramp or something and measure the clearance.
Let us know if you find some 5x130 71.6mm hub-centric spacers, I may be looking to run a pair in the rear myself, depending on what wheels I end up with. I'll only be using 20 or 21" rims and the standard fender lips, though.
