Removing Steering Wheel Cover
Does anyone know how to remove the steering wheel cover (the thing you hit to sound the horn, and behind which is the driver airbag module). I’ve got a subtle rattle behind the cover and don't want to waste my time bringing the car to the shop only for the tech to say he doesn’t hear it. Something may be loose that needs tightening. Should be easy to remedy. But there are no screws that I can see, and I don’t want to start messing with the cover to pry it off because I just know I’ll ruin something or mar the steering wheel or cover and then I’ll have to look at that for the next few years. Thanks.
That IS the airbag module. You insert a flathead screwdriver in to the small holes you see around 4 o’clock and 7 o’clock (with the flat of the blade aligned parallel to the steering wheel axis) and push inward towards the airbag module. This pops out a spring loaded clip in each side and the airbag module will pop out. Careful, as the airbag is still connected...
Thanks, Mech33 and meyecul. Given your cautions, I think I’ll not play mechanic and instead take the car in for service. I’m fairly handy at fixing things, but without a service manual it seems that working with or around an airbag module probably isn’t the smartest thing to do.
normp (12-18-2019)
