Question: IF you have air suspension ...
... do you have a preference for chassis height? No matter what driving mode or damper settings? And why?
I think the car looks better down low, 95% of the time. Sometimes I change my mind, thinking it looks like a station wagon, and run it on medium. Sort of schizo on that right now. I do feel that when the dampers are in comfort that the low chassis height stabilizes the car and it does not feel so top-heavy and swaying around a bit. Thoughts appreciated! Thx!
We roll low in our Turbo all the time -- much prefer the closed wheel gap. Haven't had a need to raise it, even on the occasional steep parking incline, curb or driveway. But it's good to know it's there.
There are other threads on this issue -- you'll find some good insights elsewhere. But in our case, we have the 21" performance all-seasons on our Turbo. Individual settings are set to Low ride height and Sport PASM. Ride is firm but controlled, with no discernible float, with decent comfort over some really bad roads in and around Dallas. Cranking PASM back to Nornal, even in the low suspension height settling, really cushes things up. It'd be good for high-speed touring on the highway, and just puddling around town. Normal provides a much more compliant ride -- very comfortable.
Hope this helps.
Hope this helps.
We have been rolling on the low position all the time too on our E-Hybrid but have you ever tried to drive on regular height to see if it was more comfortable? We only have the Cayenne for the past month so we don't have much feedback yet.
I was under the impression you couldn't ride around on the lowest setting with air suspension? was told it only lowered that low when the speed got above a certain speed like 130 mph or something to provide aerodynamics and keep the car low?
You can ride in low all the time and it also has active aero so when it reaches 80MPH it automatically goes into low for.... there is an indicator that shows it going into low after 80...
No you can’t, lowest setting is loading level, it will raise over 15km/h
Drove a E Hybrid Coupe all day and can assure everyone that the LOW SETTING can be used all day with AIR Suspension..
And the drive comfort was superb .
Shame that the overall ride was not to my liking — poor cornering due to weight — and brakes were a joke .
Plus fuel economy was 24 MPG after 220 miles — so much for ECO Warrior .
Hope this helps.
Hope this helps.
I like a smooth drive and ride, so my preference in smoothness is as follows on my 2019 Cayenne S with air suspension:
The high height chassis setting only lasts until the speed gets to around 50 mpg then goes back to medium
The terrain height chassis setting only lasts until the speed gets to around 25 mpg and then goes to high
- Lo height chassis
- Medium height chassis - Default
- Medium height chassis - Sport shock setting
- Lo height chassis - Sport shock setting
- Medium height chassis Sport plus shock setting
- Lo height chassis - Sport plus shock setting
