Tailgate handless opening issue
Does anyone experience this issue?
I hardly able to open the tailgate with the kick motion with single kick. The tailgate opens after a few kicks.
The worst time was the tailgate remain closed after 7 kicks..... making me really want to kick the bumper.
Thanks in advance
Thanks in advance
The worst time was the tailgate remain closed after 7 kicks..... making me really want to kill the bumper.
Thanks in advance
Thanks in advance
You have to stand dead center, about one away, and have the FOB on you. Kick has to be one motion up towards the center of the underside of the bumper and then back down. I can do it every time just seems much slower to do than hit the button. I have yet to have my hand full. So, maybe then it will be a benefit.
However... I rarely use it, and neither does my wife. We both feel a little stupid. We mostly just use the fob or hatch button instead.
The motion sensor is reactive to when you bring your foot backwards. So if you hold your foot still underneath the bumper and you bring your foot back at a normal tempo it will open. Most think its the kick forward that opens it. It is the exact opposite...
And then as soon as you thing it works great, it decides not to work for awhile. My wife and I have also experienced that you can be loading groceries etc in the back, and the hatch will decide to close on your because it senses your feet under the bumper. Not safe actually. Probably a feature best left to minivans since they couldn't get it right
The crazy thing is (at least in my Panamera Sport Turismo...assuming same for Cayenne) is that it can be tricky to *open* yet has a hair trigger to close on your head as you're loading or unloading stuff. Accidentally put your foot under the bumper and look out!
Thanks everybody.
"The motion sensor is reactive to when you bring your foot backwards."
----> Works better... 1 out of 3 times instead of 7 times
"And then as soon as you thing it works great, it decides not to work for awhile."
----> Exactly
"it can be tricky to *open* yet has a hair trigger to close"
----> 100% works on closing
"Here are two solutions."
----> Gonna learn whistle
Look like mine is normal.....
Another trick....
Just rumbling "I am taking you to services to check out" 100% works.
----> Exactly
Another trick....
I also had it close on me 4 or 5 times, after which I said F it and turned off the rear hatch comfort access feature via the PCM. I never used it to open the hatch anyway, and constantly having it close on me while I was leaning inside the vehicle moving stuff around got to be super annoying.
I can’t figure it out the foot swipe on a consistent basis either....
On a related matter: does anyone know how to stop the tailgate to stop wen it senses an obstruction? It seems to auto-stop at the top 1/4 but does not stop for the remainder of the way down. Seems to me a safety hazard.
