APR tune for Cayenne
Here's the link to the testing engineer interview. He says that all Cayenne and Panamera engines are now built to the "hybrid cold-start" specifications. He doesn't mention Audi.
https://www.topgear.com/car-news/ele...rsche-engine#1
No. Still haven't cracked the MG1 ECU. Whoever cracks it will have a plethora of money due to the large amount of vehicles utilizing it.
As a 4 platform user of APR software I can attest that their OTS (off the shelf) software offerings are some of the best out there. The drivability is unchanged from stock and most importantly, APR is not chasing max power for any platform. Their M.O. is simply to add power, safely, while maintaining a factory-like driving experience. My S6 was rated at 450hp stock, I have upgraded Audi OEM turbos and APR stage 3 OTS software, both ECU and TCU (engine and transmission tunes). The car now has 750hp and drives exactly the same as it did the day I drove it off the lot. Truly incredible testament to their abilities. APR doesn't care about being first to market or dyno-ing at the most power, they care about quality. And it shows
mglane83 (07-22-2019)
Still not out. No one has cracked Bosch MC1 ECU. JB4 is an option.
Just got off the phone with APR and they will have a tune for our case with the Bosch MC-1 ECU by the end of the year. Expect 400/400 or more. They have significant market pressure to get this out as the on tune will cover Cayenne, Audi s4, and Panamera base, and SQ5. This is exactly why I ordered the base car!!
Definitely carefully consider the likely voiding of the powertrain warranty associated with such a mod. Gotta pay to play, as they say!
Audi is the absolute worst German manufacturer in which to modify vehicles. They have the best software detection diagnostic tools in the world. Up until a few years ago, if you had a modified ECU tune, and were completely flashed back to stock prior to a dealership visit, you had a great chance of not being detected. Those days are gone for any Audi vehicle. Audi can and will refuse to fix your windshield wiper fluid system if you have aftermarket software on your car. Even though the modification you did could have absolutely no correlation to an issue, they can refuse to fix under warranty.
For Porsche, it is generally different. I have a multitude of relationships in this brand from GMs to technicians and the consensus is that Porsche is much more lax with their warranty and aftermarket. Again, your relationship with your dealership and technician is most critical in this gray area. However, GENERALLY Porsche will honor warranty work even if aftermarket items exist on a car if they are not easily correlated to each other. If you tune your Porsche and your engine starts leaking, you will most likely be **** out of luck. In the above example re the windshield wiper fluid issue, Porsche generally wouldn't bat an eye at an ECU tune in that situation.
Mech is 100% correct, though. You pay to play. And there is always risk in modifying cars when dealing with warranty. My advice as a long-time modifier, have a conversation with your dealership and/or technician. You can generally feel them out as to their flexibility and that should help factor into your decision making process
While I have seen this happen with my own vehicles and others', the Magnuson-Moss Warranty Act (15 U.S.C. § 2301 et seq.) provides protections to consumers who have a failure that would be normally covered by warranty, and which failure was unrelated to any service, lack of service, or (specifically) modification made on the part of said consumer. Failure due to lack of oil changes are not covered, but failure due to the engine's excessive consumption of oil or inability to hold oil, are. Dishonoring a warranty claim for a coolant system failure should not be allowed due to a bolt on after market muffler. Taking your example; to dishonor warranty coverage, the manufacturer would have to state the extent to which the engine management software the consumer installed contributed to the failure of the windscreen fluid system. A highly unlikely correlation, but then again, computers can get weird. There is of course a plethora of argument on both sides of this debate, especially given that so much of our vehicles is being regulated by computer software now. It certainly does help to have a good relationship with your dealer and to establish that you do appropriately care for you vehicle in all important areas.
Needsdecaf (02-04-2020)
