NEED HELP! 2012 Cayenne V6 - Right-front parking light replacement
Dear Enthusiasts,
I got a warning "Check front light parking light" a few days ago. Turns out that the additional headlamp in park position doesn't light up (solid Led light line). However, in drive mode, it lights up fine where the lights come up as "diamonds".
Contacted Suncoast and they told me its a $295 replacement (Bumper Light Assembly) : https://www.suncoastparts.com/product/958BX4.html
Question: Is there a way to change the led bulb inside the assembly without replacing the entire part?
Please advise and thanks in advance.
Best,
Les Grossman
Best,
Les Grossman
Received 1,141 Likes
Welcome to the forum Les- dunno if there is any way to change the LED bulb inside the assembly. Replacement parts are not available AFAIK, and usually that sort of assembly is heat-welded together and not meant to be serviceable. You might check with some wrecking yards and see if they have one.
I'm also moving your thread to the 958 subforum - since that's what you have - and people in the know on this model are more likely to see it there..
Hang on...
Hang on...
