Electric trailer brake controller, questions/help requested
I'm going to pick up a new enclosed trailer with electric over hydraulic brakes next month and I need to install an electric trailer brake controller in the 2016 Cayenne.
Has anyone done this?
What should I get, that is hopefully plug and play or easy to install. I have the factory hitch and the factory 7 way round, but that is about all I know.
https://www.etrailer.com/tv-install-...reg-90885.aspx
Since the Prodigy RF isn't compatible with EOH brakes, I'd suggest the RedArc pro or Prodigy P3 controllers. The RedArc only requires one hole to be drilled for the adjustment ****, and it the least obtrusive of the bunch.. https://www.etrailer.com/Brake-Contr...BRH-ACCV2.html I've pulled for many thousands of miles with the P3 in my previous truck and was very happy with the smoothness of it. Had the RedArc been available when I bought the P3, I would have done that.
GrandPaJohn's link covers the actual install well.
Thank you 1,000,000x. I truly appreciate the help.
Might the Touareg parts numbers also be the same for our Cayenne's?
Eskimo1, I had considered the Prodigy RF and wish I could have gone with that plug-and-play option but you are correct, it will not work with the EOH setup I'll have/be going with.
I have seen the RedArc and will probably go with it and your recommendation.
Thanks. I just got back from going up into the space above the brake pedal and found the foam wrapped harness easy enough.
I liked the video that eTrailer posted with the install of the Prodigy, it is easy enough to do for sure. I was worried that I would not have that harness/plug but it was/is under there. Thanks for posing the link to eTrailer GrandPaJohn, it was super helpful. I did order all the parts from ECS tuning for about $32 shipped. I'm going to order the Teknosha Prodigy P3 and wire everything up so when my trailer is ready, sometime around 02/22/2018, I'll be ready.
Again, much appreciated.
I may have to look into what it might take to convert my boat trailer to EOH as right now it is surge. As a Titan EOH actuator alone is around $650, I think I'll stick with the surge brakes on all 4 wheels that have a full S/S setup on each wheel and have been working well. Maybe when I'm flush with more cash I might do the conversion but for now, just getting a Prodigy P3 will be enough.
I have a new PROLine SNO 714 enclosed trailer on the way and it comes with the EOH brake package on 15" galvanized wheels/Dexter Torflex axles. I had asked if the brakes hold up to the winter conditions/salt/road chemicals we get in the winter and the answer was that they do hold up. I'd prefer an all S/S caliper/rotor, brake pads and even hubs like are on my boat trailer but I'll see how it all goes as the winters roll on by.
Thanks again all.
I was able to easily find the factory foam-covered trailer brake harness just dangling up under my dash.
I got the four yellow wire harness from ECS for right around $30 and the VW parts numbers on the etrailer site are the same as what we use on our Cayenne's.
I bought a Tekonsha Prodigy P3 and wired it all up, plugged it in and mounted it last night and it works, even though I don't have a trailer hooked up, it works and the install was pretty simple. 3 more weeks or so before the trailer is finished.
I got the 7-way plug installed and hooked to my trailer just to see if I got any warnings about lights out, and was seeing intermittent issues.. Turns out the factory wiring that plugs into the 7-way plug has corrosion on the connectors. Looks like the factory "cap" isn't sealed.
Fortunately, the dealer is getting me a replacement under warranty.
I have corrosion issues with my trailer's plug. If the trailer sits a few months I usually have to dick with it a bit before I get the lights to work consistently. At first I thought it was the tow vehicle, but 3 tow vehicles later the problem is still there. Recently secured indoor climate-controlled storage so hopefully it'll be better this year...
