PTV Differential Fluid
Going to be changing all the fluids in a newly acquired CTT. Going with the Castrol 75w-90 in the front differential, REVENOL in the transfer case. But I'm at a loss for the rear differential.
What fluid have people been using in the rear differential with PTV+?
Received 1,141 Likes
"Better questions get better answers" - Me.
I'll move it over.
There is a specific oil for PTV rear differentials.. I suspect it has a slip additive allowing for some slip under normal use. You may want to check with Porsche for the PN, then try Googling it to see if a cross-reference shows up. I believe in one of the threads someone had done that, but apparently your search didn't turn it up.
The Porsche part number is 043-300-37 ($82.24) The only alternative that Pelican had was Motul. I was just inquiring as to if others had tried that or anything else with success.
So that's my qualified NO. You haven't given us enough info (like a link to the Mobil-1 oil you were thinking of using) to make a rational YES/NO decision.
If it was me - I'd just mail order the "right stuff" (ie - Porsche juice) and do it. How many times do you expect to change this fluid? It's not a major expense difference in the long term to go with the right stuff - and it might present a significant savings if using the wrong stuff causes some damage to the driveline.
YMMV,
good point.
i called my local dealership this morning and they do not sell by the qrt.They have a drum full of the stuff in the back.
that means i don't get to do it this weekend as i have to order.
He did mention it's in fact 75-90 however he's not sure if it had additives or make of fluid
Just sharing my experience but I went with the Ravensol and it lasted a couple months without the walnut crunch on left turns and now it’s back. Switching to the Porsche lube this weekend.
