Sponsored By:
Sponsored By:
958 Cowl Drain Clean Out - DIY
Old 05-21-2017, 01:35 PM
CAVU
CAVU's Avatar
Default 958 Cowl Drain Clean Out - DIY
While the wife is in the field teaching the little ones about nature, nature leaves lots of presents. Leaves and debris.
This is something you want to consider because clogged cowl drains will raise the water level to a point that water can enter the cabin and make its way to things that are electrical (boxes and wiring).
The 958 cowl drain access is different than previous models. Using my preferred maintenance method , I plan on doing this at least once a year, if not more.
There are two maintenance methods:
1. Partial release of the wheel liner mounting screws and nut (My preferred)
2. Full release of the wheel liner from its screws, two nuts, and complete removal of the liner.
Jack/Lift points are in the owner's manual and at http://www.porscheownersmanuals.com/...-with-the-jack. My floor jack has a large rubber disc so I did not use a alternate puck.
Tools:
1. Jack, Jack stand or equivalent, and wheel removal and fitment tools
2. 10mm socket
3. T25 bit
4. Favorite socket wrench or hand electric drive (my preferred)
5. flat head screw driver
6. Garden hose (NO PRESSURE WASHER)
Pictures speak to the procedure. Good luck!
mikegally (08-22-2022)
Old 05-21-2017, 09:21 PM
BenCD
BenCD's Avatar
Top notch post. Thank you.
Does anyone know if this is the same on a 958.2/2015+?
Old 05-22-2017, 04:29 PM
r553
r553's Avatar
Agree, very thorough post.
Can these drains be deleted? I don't see how they would keep water out when fording a stream.
Old 05-22-2017, 08:28 PM
CAVU
CAVU's Avatar
The ac drains are lower if i recall. The cowl drains are much higher. Some recommend not reinstalling the rubber piece pictured but since there is an opening in the wheel well to the engine compartment no sense inviting heat and engine compartment smells into the cabin and electrics in the cowls. JMHO.
Old 05-22-2017, 09:28 PM
gnat
gnat's Avatar
Thanks CAVU. Will have to try it this weekend. How you are supposed to do a good job cleaning under the cowls with all the stuff they crammed in there is beyond me
Mine spends almost no time under trees and when I pulled the cowl covers both sides are packed full of debris
So PSA to all those (like me) that think theirs are going to be clean as it doesn't see many trees: pull the cowl covers and look, you too might be shocked!
Old 05-25-2017, 03:47 PM
gadgetrex
gadgetrex's Avatar
Really nice description. Is there any way to do this with pressurized air, say once a month, to avoid the build up (recognizing that you probably need to do the thorough cleanout first)?
Old 06-02-2017, 11:12 AM
TheUnscented
TheUnscented's Avatar
Is there a jacking puck that we should be using with our floor jacks & jack stands for the 958 Cayenne?
Old 06-02-2017, 06:05 PM
KBell
KBell's Avatar
You will be amazed with just a simple Hockey puck.
Old 06-04-2017, 09:38 PM
CAVU
CAVU's Avatar
Good question. I updated the DIY with this link which is also in the owner's manual. http://www.porscheownersmanuals.com/...-with-the-jack
Since my floor jack has a larger rubber lift point I did not add additional protection.
As to a jack stand. Safety first. I used my drive on ramp platform and placed it under the lower control arm. No issues.
Old 06-04-2017, 09:40 PM
CAVU
CAVU's Avatar
Based upon my experience I would not use compressed air to clean the cowl out. However, I might be inclined to use it to loosen things up a bit followed by the water to push things out.
Old 07-21-2017, 05:16 PM
r553
r553's Avatar
Today using this post I tackled the cowl drain clean out. I chose to remove the rear of the fender liner and was able to turn the wheel in to get to the required rear fasteners of the liner. The drains were pretty clear but I chose to remove both of the cowl drains and snipped off the AC condensate drain flapper valve. UPDATE: To get to AC condensate drain I had to drop the plastic under tray.
Left to right are the driver's cowl drain, AC condensate flapper and passenger's cowl drain:
Last edited by r553; 07-22-2017 at 07:37 PM. Reason: corrected access to AC condensate drain
Old 07-22-2017, 06:57 PM
Chaos
Chaos's Avatar
Thank you!
Old 08-18-2017, 02:04 AM
deilenberger
deilenberger's Avatar
Received 1,141 Likes on 758 Posts
Getting added to the 958 DIY forum.. thanks much for the very informative write up of something almost everyone who owns a Cayenne will have to face sooner or later.
Old 09-16-2017, 07:36 PM
rol607
rol607's Avatar
Awesome tutorial, thank you!
Mine were clogged!
Old 09-18-2017, 11:50 AM
wakame
wakame's Avatar
Mine were clogged!
how can you tell if you drain is clogged without opening to check?
Quick Reply: 958 Cowl Drain Clean Out - DIY
